One very sick Hilux solid front axle
Full rebuild ...
-New wheel bearings
-Swivel housing kit including new king pin bearings
-New standard birf (cv's) both sides... only weak link was planing on replacing with longs later
-IFS hub swop for extra width
-New vented and slotted cruiser disks with 4 pot IFS calipers (as good as it gets for hilux
-Seriously reinforced main axle tube with a diff shave for xtra ground clearance and a super heavy "U"bolt eleminator setup with leveled spring perches for use with non-standard springs (standard has the passanger side 10mm lower
-Custom extreme lift X-over hi-steer steering arms (these are extreme they put the tie-rod almost above the diff head well out of harms way
-"Beef" welded swivel housings sporting grade 12 button head steering arm bolts to stop the standard studs being pulled (should be approx twice as strong)
-And lastly but not least a tightened LSD on new bearings 4.56 ratio
A fully rebuild 5M motor
-Crank grind with new bearings
-New pistons rings etc .5mm oversize
-etc etc $2800 spent on it
Rebuilt 5 speed G52 box
-All new bearings all selectors gears etc within spec
Dual Gearbox adapter to run to G52 boxes
-This is a bit rugged as I built it more as a mock-up for a alloy version but that said its built very solidly 10mm plate
W55 Bellhousing yes a sort after M series manual bellhousing
Surf IFS rear axle that has been shaved, diff cover reinforced and pinion rotated sporting a set of alloy mounting plates to mount hilux solid disk two pot calipers (could possibly be talked into throwing some reinforcing on similar to the front axle... was planing on doing that at some stage anyway
4.56 diff head on new bearing and fitted with a new lockright lokka... never used
4.3 open diff head
4.56 open diff head
New set of vented IFS front disks that have been slotted
I'm certain there is other stuff there but that will go on as I stumble over it
And for those with a few bits I'm after a couple of 4.1 fine spline cruiser diff heads....pretty certian thats 70 series on
Cheers Reece
