IFS surf owners
IFS surf owners
might interest you surf owners,on trade me, give you guys a cheap lift
http://www.trademe.co.nz/Browse/Listing ... =106033307
- NA_Drifter
- Bush Crasher
- rangimotors
Re: IFS surf owners
PigFmr wrote:might interest you surf owners,on trade me, give you guys a cheap lift
Keep me Posted Please !!!
All Sorted now
20mm go sraight in
25mm ones require a bit more work about 1hr to do each side
you have to drill and tap the ball joint so the two bolt holes nearest the engine take a 10mm bolt and put bolts in from top through wishbone and spacer and tighten into ball joint the two nearest the wheel need to be drilled to take a 10mm nut and bolt
If you have wound your torsion bar up check when suspension is at max drop your cv still turns because i choped bump stops down angle was to steep put new bump stops in and all is fine
Will be putting only 20mm ones back on trade me as to many idiots out there and cant be arsed to explain it all on there
http://www.trademe.co.nz/Browse/Listing ... 90&ed=true
Kev
20mm go sraight in
Kev
