Al
safari clutch
safari clutch
Replaced the clutch master cylinder the other day and bleed. Noticed the next day clutch slipping slightly. Adjusted the freeplay in the pedal but continued to slip. Then I re-bled the clutch with the engine running IE: vaccum working, and it all seems fine now. Questio: do you think the clutch slippage was due to hydrualic backpressure from bleeding without the vaccum pump running
Of note the factroy rear locker (vaccum/electric) would not engage until I had released the back pressure in the clutch system.
Al
Al
