More height on a Bighorn
dazza85
Post by dazza85 »
I have a standard '89 Bighorn.
It has leafs at the back and IFS at the front. 30" tyres
When out last weekend I had a few problems with ground clearance
What would people recommend as the best way to gain some height.
truck-fixer
Post by truck-fixer »
Drive with one rut down the centre of your vehicle so that the left wheels are on one side of the rut and the right wheels on the other. This way you won't belly out. :wink: Suspension lift probably best. See your local 4WD upgrader and get it done properly of you want it for road use too.
DaveM
Post by DaveM »
If it was the front rubbing, lift it, if it was the rear diff, you need bigger tyres.
Do both 8)
dazza85
Post by dazza85 »
truck-fixer wrote:Drive with one rut down the centre of your vehicle so that the left wheels are on one side of the rut and the right wheels on the other. This way you won't belly out. :wink:
I did that with the shallow ones ...
The photo above was taken at the end of one of the deep ones ... the bank is half way up the windows
I was told that when you try to drive with one wheel down the center and one on the side the wheels on the center tend to slip off into one of the ruts, and this can result in more problems ...
dazza85
Post by dazza85 »
DaveM wrote:If it was the front rubbing, lift it, if it was the rear diff, you need bigger tyres.
Do both 8)
On some bogs it was both ...
Bigger tyers ... I know how to do that $$$
How big can I go before I have to do a body lift to fit the tyres ??
Whats the best way of lifting the front
DaveM
Post by DaveM »
Front is easy, you just wind up the torsion bars, back would be longer shackles?
Not sure, but with a 2" lift you should fit 32" tyres?
What size do you run now?
dazza85
Post by dazza85 »
I'm currently running 30" tyres ...
I know its not the answer your looking for but sell it and buy something BIG with BIG wheels. Always works out cheaper in the long run :wink:
dazza85
Post by dazza85 »
Sadam_Husain wrote:I know its not the answer your looking for but sell it and buy something BIG with BIG wheels. Always works out cheaper in the long run :wink:
So what would you recommend ???
dazza85 wrote:So what would you recommend ???
it all comes down to personal preferance, budget and what happens to come up while your looking
but I could always be biased by suggesting a Landcruiser/chev combination :wink:
