Well Steve, have I got a storey for you..........
Not only is the supra going in, but a whole swag of other changes too. With next year being the inaugural national winch challenge series kicking off, I have gone mad and am turning my perfectly good Hilux into a winch challenge machine
The list includes:
36"x 12.5 Simexes with Secondair beadlocks
Rangy coils to give 100mm suspension lift
3 link rear with /\ shock setup
probably radius arms and panhard in the front
Rancho's all round
move front axle 50mm forward
50mm body lift
ARB front locker
Detroit EZ locker in the back
5.29 diff gears
CV'd driveshafts
full roll cage
mid mounted Mile Marker 12000lb Hydraulic winch
cross over steering
full floating rear axle with hilux front discs and commodore rear calipers
transfer case flange handbrake
IFS surf vented discs and calipers
50mm transfer case/g'box and engine lift
low profile t'case x member
shaved and braced diff housings
Aircon pump compressor for onboard air
move fuel tank
wider track
race seats and belts
Longfield cromo 32 spline c/v's and axles
so far in my hot little hands I have the air locker, longfields,diff gears,winch,dyneema winch rope,seats, belts,all the bits for 4w disc conversion.
The first event for the new wagon is the Palmy winch challenge at the end of Sept, so Ii have only six months to get it all done
Hence the 6hrs I am spending on it after work every nite
I am designing 90% of the stuff on cad software(my day job) so hopefully that will take all the guess work out and things should go a bit smoother.
I have posted a few pic's in my album, but they are a little old. I'll try and keep a regular flow of pics comin as progress is made
