Replacing bonnet catch with pins
Mattman
Post by Mattman »
I want to fit a 16in thermo fan to my Hilux but it will require modification of the front panel where the bonnet catch mounts.
Without a lot of fab it will mean losing the catch assembly and verticle strut.
Are bonnet pins on there own acceptable for WOF standards?
Anyone have any thoughts?
Matt.
MATT4U
Post by MATT4U »
As far as I'm aware they are, I hope they are cause I have just removed mine and fitted pins alone.
You shouldn't need to remove the latch to fit a fan, and with the standard engine in there just remove the viscous fan and fit it behind the radiator
Mattman
Post by Mattman »
Thanks Matt.
I have a 1UZ in it and its currently running a commodore rad and 2x10in fans. I plan to go to a cruiser rad and a single 16in.
The test fit I did yesterday shows that I will need to cut out the bottom brace that runs horizontally and also remove the latch assembly.
If I don't remove the latch then the fan needs to sit too far down and I would prefer it to be further up. If I keep the latch then I also need to fab up a new vertical brace to support the top latch mount area.
With the 1UZ the radiator has to be as far back as possible for clearance.
Matt.
wjw
Post by wjw »
16in aftermarket fan? one of the black ones?
Who knew Prados could fly?
Steve_t647
Post by Steve_t647 »
Last time I ran pins the requirements were you had to have 2 pins (I had 4 and the whole bonet lifted off it was a quarter mile car after all) and the bonnet cannot be sprung up (bonnet held down on bump stops).
Also the pin's had to be wired to the bonnet, and the area pinned was strengthened.
Perhaps a certifier will be better suited to ask this was what I had to do to run on the road. Oh and the boot was pinned too (less weight)
Mattman
Post by Mattman »
It's a Wysco 16in fan. Rated at 2450cfm apparently.
Does anyone know if you need a cert for pins?
Jafa
Post by Jafa »
The LVVTA cert threshold document found here
http://www.lvvta.org.nz
Page 2 states that engine hood pins do NOT reqiure cert
021 273 9942
jafa@inspire.net.nz
wjw
Post by wjw »
Mattman wrote:It's a Wysco 16in fan. Rated at 2450cfm apparently.
i just got sa vl commie one 4400cfm
Mattman
Post by Mattman »
Is that a twin fan setup Bill? That CFM figure is quite high.
I have done quite a bit of research on fans and 2400cfm is about the most you will get from any fan, assuming you believe the manufacturers figures.
A lot of the 10's and 12's are about 1400cfm with the top quality units around 1600CFM.
If you work out the area coverage you are better off with a single large fan than you are with two small ones, assuming you can fit a large single that is.
Matt.
basics
Post by basics »
in strong wind my bonnet lifts up, scears the crap out of me.
im interested in getting some pins too, post some pics when your done.
who sells them? repco?
If its lifting it might just need adjusting....
basics
Post by basics »
Jerry wrote:If its lifting it might just need adjusting....
ill have to have a closer look, didnt even know you could adjust them. :oops:
