help...buying new rims
ok... im going to order some new 15x8 rims for the zuk, i want to go as wide as possible,i am putting my 31x10.5s on it, what are the off set mesurements??
if buying new you can just say... sj413 rims, or you can specify you want lots of offset etc. only thing they may mention is that you may need flares but as soon as you mention that you are puting them on a dedicated offroader they are usually fine. i got crusier offset wheels for my paj and the guy on the ph at bg marketing (wheel supplier) was telling me black and blue that they wouldnt fit. i had alot of fun calling him up and saying they fitted...
also, in your other thread you said your old rims are farked, what makes you say it? if its a few dents on the outside edge or somthing, why not get bead locks? a bit more $$ than new rims, but you will get width (half or maybe 1 inch extra), and able to run low pressures. and you could get the centres moved or somthing at the same time?
just a thought...
just a thought...
thanks guys.... wacko> the rims i got second hand are rooted, centers already moved and as wobbly as fark!! oh and very rusty too,but good for getting guards cut.....
toysuzi> Ill check out the f150 rims cheers
DB> who did you go through? ive been quoted 80-90bucks
DieselBoy wrote:Give Simon at Tyre Power a call on 0272714323, he might be able to help you out. He used to be competetive with most tyres shops, even with shippin to people round the country on top of the cost price!!!!!
OR HIS SHOP LINE IS (07) 856 7185
