I am concidering putting a turbo onto my vitara engine but am unsure weather or not the front diff will handle the xtra power that the turbo will generate. I no the engine will handle it as we have already run this turbo on this engine but in a truck that was running hilux diffs.
what do you guys reckon.
Turbo
you will need to stock up on front diffs if you do that , mine has cam ,head work inlet and exh mods , maybe 100hp and i get about 2 trips out of each front diff (i have been told i am ####### rough though)
, i either brake the casing or blow spider gears to bits or rh axle or all of the above
can allways drive out but
now i try to be gentle
go the hilux diffs cheers
vaughan
vaughan
