LN130 Surf/Lux manual electrical aerial switch
Mattman
Post by Mattman »
Does such a thing exist?
My LN61 had a manual switch and I would like to put one into my Surf to have some control of the aerial.
I have just installed a new stereo into my Surf and it keeps the aerial up even when the CD is playing which will leave it prone to getting knocked off.
Matt.
worzel
Post by worzel »
Just run the wire from radio to the ariel though a switch you can then do it manually
Ihave fitted one to mine so when off road can retract it and still listen to cds or radio
Kev
jarps
Post by jarps »
my surf did the same thing so i had a switch fitted so it can raised and lowered manually and to whatever height you want., just cant remember how it was done.
Mattman
Post by Mattman »
Thanks guys, I don't have a problem wiring it up, I just wondered if there was a factory manual switch available for the LN130.
I plan on keeping the auto function but add manual control as well. I would prefer to use a factory switch if possible.
Matt.
