Cruiser HJ75 radiator mounts question
Mattman
Post by Mattman »
I have an HJ75 radiator that I am fitting to my 1UZ powered Surf.
Does anyone have any pics of the mounts in an HJ75 or equivilant Cruiser?
These appear to use rubber bushed horizontal mounts on the side of the radiator and I want to replicate the mounting.
Matt.
I think the top mounts are verticle through small brackets and the bottom ones are horizontal through the front bulkhead panel
Mattman
Post by Mattman »
Thanks for the pics.
How is the mount itself made up? Is it just a rubber bush through the hole in the radiator mount sitting on the bracket below held in with a bolt?
I wonder if the bushes are available - anyone know?
Matt.
from memory the rubber bushes are 2 piece and I think a small crush tube through the centre? I think all 4 mounts use the same bushes. :scratch:
Mattman
Post by Mattman »
I might pop down to toyota and see if the bushes and tubes are available.
Would it be worth contacting a dismantler to see if they would chop the mounts off?
Anyone know of a suitable truck being broken up?
Matt.
all 70 and possibly 60 series will probably be the same and theres heaps of them getting wrecked around the place :wink:
See what suitable parts Turoa has in his wrecking yard....he may have something to suit :lol:
mud70
i might have some
Post by mud70 »
ill have alook tonight when im home :)
Mattman
Post by Mattman »
The rubber bushes were available brand new from mr Toyota for $25 for all four which isn't bad.
The upper mounts are also available but they are $130 each!!!!!
For a triangle with a stud it is pretty expensive, I was amazed they were available though but will make my own I think.
The lower mount appears to be just a bolt through the support panel which should be easy enough to replicate.
Matt.
Jafa
Post by Jafa »
Sadam_Husain wrote:Image
Nice!, tree fiddy?
021 273 9942
jafa@inspire.net.nz
