rear vents?
Posted: Thu Jul 19, 2007 2:10 pm
by Dace
Hey people, it seems to be that most cars, inc hilux, landcruisers, prados, and possible other brands, have vents in the rear "c" pillar area, i guess to allow air pressure release when ya open and close doors.
but it also allows water to gush in when ya crossin deep water
Has any one addressed this problem or do ya just have to put up with it?
One idea i have had was to rig a vent above the rear window and block up the lower ones
Any ideas
Re: rear vents?
Posted: Thu Jul 19, 2007 6:11 pm
by adogg
DBWRacing wrote:Hey people, it seems to be that most cars, inc hilux, landcruisers, prados, and possible other brands, have vents in the rear "c" pillar area, i guess to allow air pressure release when ya open and close doors.
Any ideas
like you say the vents are there to allow for air pressure release for opening and closing the doors and also for releasing the pressure in the cabin when your heater or a/c is running in --> mode rather than recirc mode,make sense? moving them would be an easy option,even maybe a roof vent??i dunno anythings possible
Posted: Thu Jul 19, 2007 10:21 pm
by Disco-Blue
Depends how cheap you are, a can of space invader and a drill would be a very cheap solution
Posted: Fri Jul 20, 2007 2:26 pm
by Bubba
Arrrrrhhh so that would be the sloshing sound I here When I throw a few anchors out the door in a hurry in a vain attempt to slow down.
Surely they have a one way rubber valve thinging to stop water from going in??
Posted: Fri Jul 20, 2007 3:10 pm
by Sadam_Husain
by SupraLux
10" of lift, 44" interco boggers, problem solved
Posted: Fri Jul 20, 2007 3:12 pm
by Bubba
SupraLux wrote:10" of lift, 44" interco boggers, problem solved
Big Wednesday would solve all those problems and anyway i like the stealth look (sorry bout the hijack
Posted: Fri Jul 20, 2007 3:44 pm
by Jerry
Nah thats your doors still full of water after that bottomless bog you found at terawhiti last weekend
Its just a mesh filter, on the doors check the drains in the bottom of them occasionally, if its full of mud poke a screwdriver up them and watch the water pis5 out
What about a snorkel?
Posted: Fri Jul 20, 2007 4:43 pm
by Dace
I haven't had the problem my self but a mates lux hit an obstical while in a river, forcing him to stop and water gushed in, will probable not bother, just air out the carpet if it becomes a pool!!!
Posted: Fri Jul 20, 2007 6:02 pm
by Ryan
you could take the vents out and weld the holes up(not a major job), but problem is finding a high place to put it if you want it back in??
Posted: Fri Jul 20, 2007 6:24 pm
by SupraLux
Cut the roof off... then you don't need the vents
Posted: Fri Jul 20, 2007 7:42 pm
by rokhound
DBWRacing wrote: just air out the carpet if it becomes a pool!!!
WTF????? If you are doing crossings deep enough to worry about water coming in the C pillar vents, why the f**k do you have carpet in it???
Bang in a bilge pump and self bailing thingies in the floor and make sur the drain holes in the doors and gaurds are clear.
Posted: Fri Jul 20, 2007 7:50 pm
by SMOKEY
If your deep enough to have water coming in the air vents it won't be for long,--------- you will be floating
, but not for long, it will fill with water and SINK.
IN TO DEEP,
FITZY.
Posted: Fri Jul 20, 2007 9:51 pm
by niblik
thats exactly why the 40's have the kick panels up front in the foot well areas fitzy :thumleft: ... get the big pigs down in the water to hopefully get some traction..
