I am about to order a clutch kit for a 89`LJ71 cruiser , the supplier reckn`s the petrol engine , assume its the 22R - is the same as the 2LT clutch ??? - sounds weird to me , want to make sure before i order it by frieght !
http://www.sunburybrakes.com.au/prod241.htm
I hear a 2LT clutch kit is the same as the petrol version ??
adventures_more
Have you used those clutches before?
They seem ridiculously cheap. I can get trade price on Repco clutches and they are more than that.
I just had a Hilux clutch made up for me, organic plate with a 2100lb clamping pressure. I got trade price on the clutch so it was a good price however it was still a lot of money.
I have found that you get what you pay for with clutches, if you are going to work it offroad hard then I would try and get a better quality clutch.
If you want to confirm the clutch then just call Repco or BNT or whatever and ask them the pressure plate part number for the petrol and diesel models.
Matt.
Matt.
Matt.
Matt.
as mattman was saying you get what you pay for, mine cost a bit but is good!Vaughan,
As per our telephone conversation for the Off-road Clutch to suit your Suzuki Vitara G16A 16v
Performance Cover Ref Part No. MB-012 215mm Priced at $185.00 Plus GST
Segmented Competition Clutch Disc with Heavy Duty Dampened Hub Part No Ref AC215CK running Fibertuff
Steelbacked Facings or Steelbacked Fullfaced Carbon/Kevlar (as per pictures) Priced @ $240.00 Plus GST
Rel Brng Ref No 374 Priced @ $34.50 Plus GST.
Vaughan as discussed your flywheel will need to be STONEGROUND to optimise the friction coefficients of the Fiberfuff
or Carbon/Kevlar Friction Material, and it also allows us to set up the unit as an assembly for pedal travel release.
vaughan
vaughan
adventures_more
my 2LT is a stocky & after much deliberation & startn something & changing my mind with it , realise its not worth throwing $$$ at it , ( Engine , etc ) I know what i want and it starts with a 'U', so just need a stock clutch , Fair enough if you upgrade the power output , so you upgrade the clutch to suit & everything else , but ain't happening for this truck.
I was qouted $500 for a New stock genuine Toyota clutch kit for it off a company on trademe that sells clutchs , Car parts in Aussie are alot cheaper , 4 X time's the people & bigger economy & much bigger buying power, alot cheaper to buy bulk ( like buying 100 clutch's over 5 ) off a Importer/wholesaler !
adventures_more
went to Ilam toyota today to see how much they are & a memember on here said they have them for around $230 , but when the sales rep told me just under 1 grand , i aint goin there for sure . Yep Valeo are pretty average brand , just got a price for around $189 for a quality Exedy clutch kit from Aussie - think i will order that one !
