Bighorn blowing fuses ... Help
Posted: Tue Jul 24, 2007 9:37 pm
by dazza85
I am blowing tail light fuses. looks like a dead short
It also controls all the dash lights and the front park lights
I have taken all the bulbs out of the outside lights and taken the complete dash apart to take all of the instrument and switch lights out of the circuit and still the short remains
Has anybody had this problem ???
Where do I look next ???
Posted: Tue Jul 24, 2007 9:48 pm
by hiluxDave
Have you checked your number plate light??
Posted: Tue Jul 24, 2007 9:57 pm
by dazza85
hiluxDave wrote:Have you checked your number plate light??
No ...
Missed that one ... back in 5 ...
Unplugged the plate lamps ... still a short ...
Posted: Tue Jul 24, 2007 10:40 pm
by kiwipete
only thing left to do is trace all the wiring loom(s) from the fuse to each light socket and you will source your short.
My pic would have to be somewhere in the front as it takes most of the knocks and punishment, the rear is usualy protected well from within the skins of the body.
Just my 50c worth.
Posted: Tue Jul 24, 2007 10:47 pm
by Mattman
If you can, insert a test light into the fuse holder, this will allow you to have the circuit active whilst tracing the short.
Follow the loom from the rear of the vehicle back and at each connector point unplug the loom. If the short goes out you have found the section of loom that is damaged.
Good luck.
Matt.
Posted: Tue Jul 24, 2007 11:04 pm
by dazza85
Mattman wrote:If you can, insert a test light into the fuse holder, this will allow you to have the circuit active whilst tracing the short.
Good luck.
Matt.
Made up a test light tonight and ground the plastic off the side of a blown fuse and soldered the wires to it ... so now I can plug it into the fuse holder ...
End to end on the loom is where I am at now ...
I posted here in case there was a spot that they always failed
The front of the wagon is full of Thompson's track mud all the connectors etc are full of it, but it has been fine for 4 weeks since then ...
OH well I guess I know what I am doing tomorrow night ...
Posted: Wed Jul 25, 2007 8:16 am
by Smurf
I had a similar problem years ago but all my lights went haywire, indicators on when braking etc. I had crushed the wiring to my trailer plug and shorted wires.
Posted: Wed Jul 25, 2007 8:58 am
by Sadam_Husain
dazza85 wrote:The front of the wagon is full of Thompson's track mud all the connectors etc are full of it, but it has been fine for 4 weeks since then ...
could be moisture in the loom causing the problem if its full of mud?
Posted: Wed Jul 25, 2007 10:06 pm
by dazza85
Sadam_Husain wrote:could be moisture in the loom causing the problem if its full of mud?
I have been wondering if that may be the case as we have had heaps of rain in the last 10 days, though it only started when the rain stopped.
I started with the back one and it came apart ok, but the one in front of t he petrol tank is being a pain
I have had a poke around the head lights and there is lots of dried mud in everything.
I'm thinking that under the fuse block could be worth checking
I probably won't get another crack at it 'till the weekend.
Posted: Wed Jul 25, 2007 10:26 pm
by rangimotors
have you got a head unit? I have had similar issues in several different cars and trucks and traced it to poor, wrong or damaged wiring to the head unit, seems its also on the same fuse as rear lights and dash, you will probably find when the fuse blows your break lights still work? but they wont go if you have your lights on.
Re: Bighorn blowing fuses ... Help
Posted: Wed Jul 25, 2007 10:33 pm
by MAHINDRACJ4A
dazza85 wrote:I am blowing tail light fuses. looks like a dead short
same thing just happened to my nissan mistral, put in two new fuses but would blow then in no time,
took it down to auto sparky, he unhooked my alarm from the lights ( so the lights dont flash when you turn the alarm on/off) it has seemed to fixed the problem
Posted: Wed Jul 25, 2007 10:43 pm
by dazza85
rangimotors wrote:have you got a head unit? I have had similar issues in several different cars and trucks and traced it to poor, wrong or damaged wiring to the head unit, seems its also on the same fuse as rear lights and dash, you will probably find when the fuse blows your break lights still work? but they wont go if you have your lights on.
Yes ..a brand new Sony ... the cheep one ... I think I checked with it unplugged ... will check again ...
MAHINDRACJ4A ... re Alarm don't have one yet, thats next payday
Posted: Thu Jul 26, 2007 9:25 am
by rangimotors
yea only my 2c but the head unit is where i would start, i have seen it time and time again (even did it myself a time or two before i realised) some factory head units light up when you turn your lights on so they have a power feed for this which if measured with a meter will have no voltage on it (unless your lights are on) and many make the mistake of assuming its an earth, or leaving it tapped to other wires or just leaving it flying around then when you turn your lights on, pop goes a fuse and it seems the obvious place to check are your lights since its what you turned on, there are other errors that can do it like a stuffed head unit, wrong wirring, a short in the wirring or even wet loom, have a go and see how you go, (could be way off the mark, but hey better to have to much info than not enough i no what its like to chase your tail around a vechicle for hours and get no where)
Posted: Thu Jul 26, 2007 9:26 am
by rangimotors
and when you say its brand new, who put it in?
Posted: Thu Jul 26, 2007 6:05 pm
by dazza85
rangimotors wrote:and when you say its brand new, who put it in?
New as in just brought it from the shop, installed by me ... understand what you are saying about the light feed ... going to unplug the head unit after tea ...
Posted: Thu Jul 26, 2007 8:56 pm
by dazza85
Well that was interesting
I did have a wire wrong ...
It seams that you were right there is a light feed to the radio plug.
Now it is not connected to anything
The worst of it is that this has not fixed the problem
Posted: Thu Jul 26, 2007 9:17 pm
by rangimotors
really you have fixed the wirring, or chopped it out and not connected it back up yet? i would of thought that fixing that problem and replacing the fuse would sort your problems. maybe something else it wrong, ill have a think..
Posted: Thu Jul 26, 2007 9:28 pm
by dazza85
Fixed the radio wiring and left the extra wire unconnected as it should be.
Look forward to any other ideas you may have.
The truck is out side ... I don't have a shed that it will fit in so I''m on here instead of working on it.
Posted: Thu Jul 26, 2007 9:57 pm
by rangimotors
all i can think of is its a short between either your full time power or your acc power, only other question is did the old head unit have a band expanded?
Posted: Thu Jul 26, 2007 10:13 pm
by dazza85
The band expander was connected to the acc power ...
I have been trying to get some of the loom connectors apart but some of them are really stubborn.
The short seems to be somewhere after the light switch is it is not there when the switch is off.
Posted: Fri Jul 27, 2007 11:33 pm
by rangimotors
hmmm as ive never owned an isuzu maybe i've come to the end of my tiny knowledge, if i was you (hard to pin point without seeing it) i would be looking for various things that are powered when you turn lights no, i no im scratching for straws but some have clocks that light up when you turn lights on, and heater controls etc have you used any of there power feeds, earths or even just knocked a wire off well wiring up your headunit etc. I could be way off track but as i say without seeing it its very hard to trace the fault.. sorry i couldn't be more help.
Posted: Sat Jul 28, 2007 12:14 pm
by squeak
dazza85 wrote:rangimotors wrote:and when you say its brand new, who put it in?
Hey.
i had this problem too when i put my pioneer headunit from my old car into my bighorn. blew heaps of fuses b4 i asked an autosparky.
the factory earth for the stereo wiring is connected to the earth for your dash and tail light fuse - dont use the factory earth wire just wire the headunit earth staight to the chassie/body. i just put my headunit earth to one of the bolts that secures the headunit in the metal mounting braket. works a treat for me, hope this helps.
Simon
Posted: Sat Jul 28, 2007 4:33 pm
by rangimotors
i second that
Posted: Sat Jul 28, 2007 7:32 pm
by dazza85
I have spent / wasted 3 days chasing a red herring
You guys were spot on
When I disconected the head unit I did not think about the fact that I had put the bulbs back into the front and back lights and so of course the test bulb plugged into the fuse holder is going to show a short ...
Went through it again and a friend came around to help and when we had spent another hour on it he asked if I had a amp meter
Poked that in, in place of the test bulb and its only 2 amps.
Thanks so much guys
More of those those good buggers
Posted: Sat Jul 28, 2007 7:58 pm
by rangimotors
ok funny how another set of eyes sometimes helps alot, all good you have it sorted.
