1uzfe temperatures.
Posted: Fri Jul 27, 2007 5:35 pm
by ELEV8
does anyone know what temperature the 1uzfe should operate at when warmed up. what is safe etc. and around what temperature is getting too high. normally mine sits at around 140, but today it reached 180. so i would imagine it would be higher offroad. just being cautious as i cant afford to do any damage to the motor.
i am also looking for a power steering pump if anyone has one.
cheers luke.
Posted: Fri Jul 27, 2007 7:44 pm
by Jafa
Posted: Fri Jul 27, 2007 10:21 pm
by Mattman
Mine runs at around 90c most of the time.
If your's is set in farenheit then it's okay, probably running a touch cold but if that's celsius then you have some issues!
Matt.
Posted: Fri Jul 27, 2007 11:20 pm
by BIG_BOY
off memory
87`c is thersmat
97`c is ECU leanest point
104`c 2nd fan(the eletric one) goes on
108`c is ECU throttle down
118`c is ECU check engin light
121`c is limp home mode
132`c is shut down via ECU
thats on the 1998 VVT ones
Posted: Sat Jul 28, 2007 9:33 pm
by ELEV8
oh yea sorry its F not C. i have got a 10 litre sump so that keeps it on the cool side. just wanted to check as i used to own a turbo rotary and i could hold my hand on the block without getting burned, when it was running. but the v8 i can touch hours after it has been running and its still hot. then again there is alot more metal to cool than the sewing machine.
cheers, just wanted to be safe and not sorry.
