no workshop manual for kzn-130??
sparx
Post by sparx »
"what?? you've got to be kidding me! someone must print one - do you realize how many of these things there are on the road?!?!"
Well, apparently nobody prints a workshop manual for the KZN-130.
Not Gregorys, Haines or even Toyota!
So where do I lay my greasy hands on all the technical information for the 1KZ-TE? Can anyone help me here I am trying to get boost pressure, oil pressure and water temperature values so I can put proper gauges on the dash and avoid cooking the head when I'm really pushing it - I'm already concerned that the oil pressure is a bit sad especially when obviously at full boost (the turbo must be hating me right now) but I just don't trust that poxy little standard gauge and I don't know what the oil pressure is actually supposed to be :(
anyone know where I can score a workshop manual for a KZN-130 or does anyone know if a KZN-185 one will be okay - as far as I am aware they are virtually the same except a facelift and ABS braking. But in saying that I also would like the correct wiring diagrams which are probably very different on the KZN-185.
what a conundrum.
-Matt
I reject your reality and substitute my own.
Found this on the interweb
"Just thought I would let people know that there is a forum with a link to a PDF of the 1KZ-TE Engine Repair Manual for donwload.
PDF:
http://www.toyotagranvia.co.uk/filedump/1KZ-TE.pdf
Forum:
http://www.toyotagranvia.co.uk/forum...2f275 bf42b7f
Hope this helps someone out there."
Hahahah leithfield posted up some info on a previous ORE thread here as well
http://www.offroadexpress.co.nz/modules ... ic&p=12591
A full workshop manual for the 1KZ-TE is available on-lin here (beware, it is a 14meg download):
http://home.swiftdsl.com.au/~scorp/surf/1KZ-TE.pdf
& here:
http://www.showmesome.info/hilux/info/manuals/1KZ-TE/
sparx
Post by sparx »
outstanding - top job.. cheer.
-matt
gotta find a 2L-Te one now......there wasn't an early prado manual either :roll:
