Roll cage cost and time to build
jumper
Post by jumper »
I am going to put a roll a cage in the 40 just want to know what yours cost and how long it took to make?
microwaved cheese on toast
sig
Jeep Jeep
Post by sig »
mine took a weekend to make the main 6 point and another weekend doing mounts and shits and bits .cant remember the exact cost but used one length of 2" waterpipe and 2 off 1.5" .i already had some of my chassis mounts from my previous cage which saved time .i,ll try and start a gallery with some photos
turoa
Pyro Junior
Post by turoa »
it might be easier to find a prebuilt one? are you going to still make the hard top fit?
jumper
Post by jumper »
Photos are always good :)
I have not seen any prebuilt ones around and i do want it to fit with the hard top on. Can you hire pipe/tube benders?
how much spare cash have you got. :?: :?:
Howat Engineering in Naenae will build you one.
Do you want a body mounted cage or chassis mounted :?: :?:
my body mounted cage took a whole day of bending and welding, only to find that when we welded it out of the truck it moved heaps. So weld it in place.
I also cut the sides of my dash to make it fit better with less bending.
I don't know what mine cost but we used 2 lengths of rollcage tube and took the best part of a day and a wee bit more.
If you want pics then check out mine on Page 38 of user pics. if you need more specific pics then let me know and I'll get some for ya.
DieselBoy
Post by DieselBoy »
No such thing as a pre-made cage.
If you can't do it your self, or know someone with the gear and know how that you and feed beer to, then you gotta drop the vehicle in somewhere and pick it up in a few days with the job all done.
I had no gear, and no idea how to build a good cage but needed one so i could progress the project. Took the easy option :lol:
The cage in the LJ took a week to get done, it was built to national trials standard, so main hoop chassis mounted, rear stays chassis mounted and front hoop floor mounted above body mounts. The whole cage is bolt in, with two seperate bolt in cross members that were fabbed up for the main hoop and rear stays.
I got it done on the cheap as the vehicle was in bits, so made the job easier for them, let them use second hand galve tube they had kicking round instead of getting in new stuff (front and main hoop made out of un-galved new tube though) and i did all the finishing off and tidying up work and got them to leave out the diagonal brace on the main hoop untill the next evolution of the truck ;) . Normally they cost about $950??
Main hoop crossmember
Rear Crossmember
Sandwich plate on the foot of the front hoop.
The finished cage (start of the rear tray in there to)
Or pop down and see Stinky....he has all the gear and metal there..... :lol: he's just down the road .... and no I'm not towing your cruiser again :lol:
niblik
Post by niblik »
wiull be interested to see pics and read the outcome of this wee thread... goin hardtop with internal cage, chassis mounted myself..
keep us informed.. :D
4WDbits
Post by 4WDbits »
Get it done correctly, and made to whatever standard you need for the purpose you have in mind.
Plying a mate with beer might save some dollars, but a bit of steam tube held together with what looks like doobs of bird shit won't save your life.
dvszuk
Post by dvszuk »
i got all my steel for my cage for $230. Got a mate of a mate to weld it up and only charged 2 boxs of beer. It took a day to bend up and half a day to weld.
Return to “Tool Shed”
