Righto, one of the engineers at work is selling his Landy, minus motor.
It's kinda like Mike's in general appearance, but it's set up for a windsor V8. It comes with the shortened C4 tranz that he custom fitted to a landy transfer. It's got racing seats etc, would make an awesome trials truck. Not wof'd reg'd or cert'd, but when I asked him, he said the major stuff he's done should be certable.
It's got a salisbury rear end, landy front, parabolic springs, 33's.....
$1000!!
Any questions....????
Highly modified Landy for sale
"He who dies with the most toys wins!!"
- mroffroader
And if he won't take $100.00 there is one (definitely was last week) on TM for that money.
You will probably only need the Series type of Salisbury which is common as muck. Unless of course your thing is set up with RR suspension.
- mroffroader
Cloggy_NZ wrote:And if he won't take $100.00 there is one (definitely was last week) on TM for that money.
damn you definetly have owned rovers!!! haha ep thats right I only need the series type of salisbury...and yes i will be setting it up with coil suspension (not sure about rover yet) but that will be later down the track after i have taken it for a few good thrashes!!
