portal axles
brakes-shocks-lockers-etc
gtblair
portal axles
Post by gtblair »
Hi, has anyone seen the marks adaptors portal axles?
Pretty cool, good clearance, and keep standard handling because all standard suspension, no body lift etc.
They are pricey (cough cough) but they reckon you can get the same ground clearance running these axles and 35s, as if you were using standard axles and 43s!
Have a looky: http://www.marks4wd.com/products/gearma ... -GQ-GU.htm 8)
mercutio
Post by mercutio »
buy a unimog :lol: :lol:
just seen one in deals on wheels for $9000 with a fertiliser bin
my 4wd is not a truck
H2OLOVA
Post by H2OLOVA »
mercutio wrote:buy a unimog :lol: :lol:
Sounds like something Lilpig needs. Then he can go places with his 31s :wink: And the fertilizer bin will give him somewhere to keep all the shit he talks :lol: :lol: :lol: :lol:
niblik
Post by niblik »
GQTROL
Post by GQTROL »
Benny Russell was running the GU portals in his middy GQ Patrol at the recent Ateco winch challenge. He broke both GU front CV's and atleast one rear stub axle. Because they raise the vehicle quite a bit it becomes unstable at higher speeds, so he dropped the suspension down to almost stock lift. This then gives problems because of the reduced bump travel that you get.
For AU$18K for the set, I would be looking to spend money elsewhere.
mudzilla
Post by mudzilla »
Not allowed in comp here anyway..and 18k buys a lot of beer. :D
adventures_more
Post by adventures_more »
you can get good 2nd hand Unimog portal axles complete for around AUS $1500 each ( remember hearing someonme bringing a shipping container full of them from germany to Aussie , they come with lockers standard as most mogs do , i think these are 404's or 406's ( 70's ) !
zukmeista
Post by zukmeista »
are u able to use these in national trials series :?: :idea:
mudlva
Post by mudlva »
why i thought you would want to keep the truck low and wide :?:
zukmeista
Post by zukmeista »
but u c loads of trucks get hung up on ruts :roll: :roll:
niblik
Post by niblik »
more seem susceptible to rolling.. or layin down.. aye rex? Image
adventures_more
I reck'n vehicle's with portal axles/diff's ( Unimogs) have an insane ability to go places where most other 4x4's can only dream of , but when they get stuck , they are generally well & truly stuck & most 4x4's would'nt be able to get them out , need another Mog , 6x6 or bigger still ( unless you have very strong winch - 10 Tonne or more & a strong winch point )
turoa
Pyro Junior
Post by turoa »
zukmeista wrote:but u c loads of trucks get hung up on ruts :roll: :roll:
Not really. The trials series rarely go where there are ruts. They create new hazards most rounds, so there isnt a problem of ruts.
De-Ranged
Post by De-Ranged »
And the winch challange rules state "No portal axles" ....
Damm at 16k :shock: thats one very expensive set...
Cheers Reece
mudlva
Post by mudlva »
here her for the coments above portals are a nice wish list item but the realalities are that if all that if all that is happening is that you are getting diffed get a good set of lockers a decent set of tyres and drive the line harder 16k will allow for this plus a lot left over for a serious piss drinking session. good luck
cheers mudlva
