cheers.
and yes, im going out this saurday to give it a good workout, seeing as i missed out last weekend
safari SWB, 33x12.5x15 muds, lsd, snorkel, pto winch, uhf cb, recovery gear
albundy wrote:It will be 24 volt and unless you run a converter it won't work. Sell the one you have got as it looks as if it has a PTO. 24v are alot faster at winching then 12v. Do not run anything off one battery as it will cause the other one to overcharge when the alternator is running and kill it. you can get converters from jaycar for about 70-80 bucks. I run two to power cb, prs, gps and phone charger up front with another in the back for floru lites whern camping and the fridge.
Al
