will my 12v superwinch work in safari 24v?
Posted: Thu Aug 16, 2007 1:34 am
by hulux-happy
Posted: Thu Aug 16, 2007 6:44 am
by albundy
It will be 24 volt and unless you run a converter it won't work. Sell the one you have got as it looks as if it has a PTO. 24v are alot faster at winching then 12v. Do not run anything off one battery as it will cause the other one to overcharge when the alternator is running and kill it. you can get converters from jaycar for about 70-80 bucks. I run two to power cb, prs, gps and phone charger up front with another in the back for floru lites whern camping and the fridge.
Al
Posted: Thu Aug 16, 2007 7:31 am
by skid
albundy wrote:It will be 24 volt and unless you run a converter it won't work. Sell the one you have got as it looks as if it has a PTO. 24v are alot faster at winching then 12v. Do not run anything off one battery as it will cause the other one to overcharge when the alternator is running and kill it. you can get converters from jaycar for about 70-80 bucks. I run two to power cb, prs, gps and phone charger up front with another in the back for floru lites whern camping and the fridge.
Al
why would you want to ditch the strong PTO unit you already have
Posted: Thu Aug 16, 2007 7:34 am
by MudBum
I scored a reducer from TradeMe for $65 landed in ChCh from Kiatia (have to check spelling) Auto Electrical.Its a continuious 15amp and its awesomely small with a wee fan mounted.We put it in behind the glovebox so its high and invisible and with the CB only drawing 3 amps it gives me room for something else.
Nice truck too dude, look forward to catching up on a trip soon.
Posted: Thu Aug 16, 2007 7:54 am
by albundy
I was meaning sell the electric and keep the pto
Al
Posted: Thu Aug 16, 2007 8:00 am
by skid
albundy wrote:I was meaning sell the electric and keep the pto
Al
good idea dude, too early in the morning for me to read between the lines
Posted: Thu Aug 16, 2007 9:46 am
by Aaron
A lot of guys run 12v 8274 warn winches on 24 volt and they work really well, I dont know about the Superwinch though.
Posted: Thu Aug 16, 2007 11:34 am
by rangimotors
if you want to sell the electric set up let me no
couple more mods as planned to my surf and you'll still have some competition
Posted: Thu Aug 16, 2007 8:40 pm
by mudhaw
The only diference between a 12volt and a 24 volt winch is the motor.
Yes you can run 24v through a 12v winch but they dont last long unless you get the motor modified.
If you have a pto keep it sell the electric or mount it on the back.
The pto is faster on a double line pull than the electric on a single (thats an 8274 high mount)
