The went to fit the pads and could not get the piston to go back
I believe that I have seized disc caliper
Can I fix it myself or do I take it to someone to get it sorted ??
adogg wrote:has the caliper got the h/brake as part of it? if it has then you have to turn the piston to make it screw it self back into the caliper,the piston will have cutouts in it if it is this model
dazza85 wrote:Are you guys saying that it is likely that it is OK ...
So old but still so muck to learn![]()
billyvanboheman wrote:Or they have an allen key under a blanking screw, on the back of the caliper to wind the piston in an out!
Can get you pics of where to look, but not till tomorrow.
