water in air intake
Posted: Sun Aug 26, 2007 7:29 pm
by jabes
ok so lets say someone may have driven thru a river a touch fast this afternoon (mistake one) and then the truck died so waited a bit then restarted it (mistake two) after it spluttering a bit it cut out again so i realized something was wrong opened the engine and discovered a bit of water in my air filter case so dried that all out and all the pipe work and stuff and then left the car for bout 30 mins started it again and it didn't like it but spluttered and coughed for a bit then was fine and i drove home (couldn't call for a tow or anything due to not being anywhere near cellphone coverage or other people for that reason).
So my question is have i done anything majorly bad ie should i go to the mechanic to get it checked out or something its running ok now but don't want to cause more damage than anything. any advice would be greatly appreciated thanks
Posted: Sun Aug 26, 2007 7:44 pm
by philux
petrol or diesel? petrol the electrics dont like water. dizzy, coil etc. Diesel dnt know much about but if its behaving like that is say it would need checking
Posted: Sun Aug 26, 2007 8:24 pm
by mercutio
if a diesel swallows water it is usually expensive things usually break
petrol you can sort of get away with it butr as mentioned electrics don´t like it
Posted: Sun Aug 26, 2007 8:30 pm
by Sadam_Husain
I've seen 2-3 diesels that have managed to recover after swallowing a wee bit of water but they all ended up disentergrating within a few weeks
seen a few that havent managed to recover after swallowing a wee bit of water too
Posted: Sun Aug 26, 2007 8:33 pm
by jabes
yeah diesel so take it that its a take it to get checked asap then
Posted: Sun Aug 26, 2007 8:39 pm
by niblik
is it down on power? makin noises it wasnt makin before? perform a compression test perhaps...?
p.s... snorkel = cheap insurance...
Posted: Sun Aug 26, 2007 8:49 pm
by jabes
it was a bit funny for about 2min when i first restarted after drying it out very very smoky too for a bit tho seemed to run fine on the 20km drive home. no loss of power or weird noises that i noticed or any smoke again.
the filter only had a slight bit of water on it like not much but enough the electrics did get wet too so presumed thats what stopped it but worried cause i heard water and diesel engines arent close friends
and yeah snorkel is definatly first on the list to buy
Posted: Mon Aug 27, 2007 10:18 am
by Swaney
Id be inclined to change have a look at the oil and give it a change and then hope for the best
Posted: Mon Aug 27, 2007 11:07 am
by albundy
If it's a safari they have a fuwel tank breather exposed to the air that can easily get water in it. Re-routwe it. Throw a litre of meths into the fuel tank, it wraps around the water molecul;e and burns it in the engine. I did this and everything worked just fine.
Al
Posted: Mon Aug 27, 2007 11:44 am
by Swaney
albundy wrote:If it's a safari they have a fuwel tank breather exposed to the air that can easily get water in it. Re-routwe it. Throw a litre of meths into the fuel tank, it wraps around the water molecul;e and burns it in the engine. I did this and everything worked just fine.
Al
that is a handy hint to know
Is it safe to do with diesels?
Posted: Mon Aug 27, 2007 11:46 am
by albundy
sure is.
Posted: Tue Aug 28, 2007 5:35 pm
by jabes
oil seems natural colour but will do the change thanks, also found and used some wynns and crc stuff for the fuel and the engine that has a water dispersant in it so put that in too,
Looking at the system it has for air intake there is a umm a sump type thing with the air intake being near the top i wonder if thats for traping water before it gets in maybe
Posted: Tue Oct 30, 2007 7:18 pm
by 1rugger
done similar thing in my last 2.8d hilux it started ran rough for 2 min's then fine then next day went to start it and it ran rough for 5min then fine, so i pulled the head off and #4 piston was about 2mm low, dropped sump and conrod was bent like banana and big end bearings and cranked where shot. so if i was you i'd get a compression check and look at replacing the big end bearings
