question for saftey freaks/experts..
rangimotors
before you tell me i can't do it, to late! well good or bad i ended up having to tow a mate back from out of town (about 30mins) with one of my snatch straps, question is will it be stuffed i no they are not meant for lifting or towing?
rangimotors
Smurf
rangimotors
mercutio
i can´t see any problem with it you won´t be putting anywhere near the forces on it that it is designed to handle and in someways you are putting less stress on your vehicle because of the stretch in the strap
only issue i can see is making sure you don´t drag it on the ground and ruin it that way
my 4wd is not a truck
rangimotors
yea but when you snatch you give a good pull and it allows its self to retract, im pretty sure if i hung a 500kg weight from it for 30 mins and then tried to snatch with it that i would find it no longer had any stretch
mike
- Last minute Mike
These are wicked little tow ropes, hold 5 ton which is more than two vehicles combined! for 16 bucks you cant go wrong. Very handy for short pulls (pull not snatch). some people think you shouldn't use them as they arnt rated to 8000kgs but come on your tow hooks are only rated to 4 or so ton!
http://www.4wdbits.co.nz/ProductDetails ... ductID=171
Mike
Mike
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
rangimotors
yea they look nice might grab one, do you reckon thats long enough for open road towing, i decided to use my 6m snatchmaster, the 3m seemed far to short for the brakes my mate has, and obviously the 10 was to long, towing was great with the small amount of stretch made things very smooth
mike
- Last minute Mike
rangimotors wrote:yea they look nice might grab one, do you reckon thats long enough for open road towing, i decided to use my 6m snatchmaster, the 3m seemed far to short for the brakes my mate has, and obviously the 10 was to long, towing was great with the small amount of stretch made things very smooth
The law states a tow rope is not allowed to be longer than 4m hence why they are 3.75m long, an official tow rope. Use these instead of destroying your precious snatch straps which are considerably more expensive to replace and illegal to tow with.
Mike
1994 Toyota Surf
1994 Toyota Surf
rangimotors
mike wrote:rangimotors wrote:yea they look nice might grab one, do you reckon thats long enough for open road towing, i decided to use my 6m snatchmaster, the 3m seemed far to short for the brakes my mate has, and obviously the 10 was to long, towing was great with the small amount of stretch made things very smooth
Mike
ah really, i had a feeling that it was something like that, thanks heaps for the help, maybe ill donate the 6mt used one to my mate who has no gear, and order a new one and tow rope at the same time.
rangimotors
fweddy
kaney
rangimotors wrote:done and done, made my order. its lucky i've got a surf and not something swb, carry so much friggen gear around my boot is rapidly filling up.
its lucky you dont have a nissan then you would have to have to carry twice as many parts that weigh three times as much. Instead of just gear
toymota thats stock standard.
Jungle
tgaguy1
Jungle, do you mean like a duty cycle, i.e. 3-4 stretchs per hour, or finite stretch count, i.e. 100 stretchs an you throw it away?
I rang cookes and asked them this question. They didn't know of any limit and the manufactures blurb they have does not mention anything either.
Thinking about it though... if it stretches you would really want to let it relax again before you apply aother load to preserve the integrity of the webbing.
I would like to know what others think or know about this.
rangimotors
hmmm interesting one aye, for example you can stretch a rubber band and let it retract all dy and its sweet, but if you leave the same rubber band half stretched for an hour or so and not let it retract, when you take it off its just not the same it looses some of its stretch and gets longer, obviously towing shouldn't of had much pressure or force on the strap compared to a snatch but then again its built for snatching and not towing, i think its still sweet but ill keep it as my back up and not snatch any nissans with it
Rural53
Jungle
Yeah sorry about that.
I meant a duty cycle. About five pulls then let it cool down and loose the built up heat.
I know climbing ropes have a finite amount of times you can fall with it before they suggest you replace it. That may be something different.
Last person i towed with a snatch strap across town drove over it and tore it in half. My own fault i suppose. If your towing someone then its your responsibility when it all goes wrong.
G
G
rangimotors
wopass
G
i will only tow people that know how to be towed for the same reason, and the tow rope was the good workshop one which i had to replace because the moron diddnt know to keep the rope tight at all times
rangimotors
with someone who knows what they are doing towing is super easy and nothing to stress about but there's nothing worse than someone who doesn't ya pretty much end up snatching them all the way, i always prefer to have the less experianced person do the towing, ya can pretty much control most things from behind
hiriklux
rangimotors
