Backspacing
ToySurf
Backspacing
Post by ToySurf »
Ive got some 15x8 wheels at home. And i measured the backspacing from the center of the wheel, To the inside of the wheel. And it was 120mm are these wheels for solid axle or independent?
Thanks
Jay K
smurf182
Post by smurf182 »
Someone correct me if I'm wrong, but by my calculations you've got a +19mm offset - pretty sure that's to suit independent.
ToySurf
Post by ToySurf »
I put them on a solid axle surf at work today. And they just clear the steering arm by about 8mm Would this create any problems?
smurf182 wrote:Someone correct me if I'm wrong, but by my calculations you've got a +19mm offset - pretty sure that's to suit independent.
I got +6 offset.
did you allow the extra inch for the beads of the rim :?: :?:
Return to “Tyres”
