i'm after a viscus fan (not sure if i've spelt that right) for a 85 toyota landcruiser. For the 3F motor.
The closer to wellington i can get one the better. makes it alot easier to get my hands on it.
wanted viscus fan
there is only 3 centres for them from 1976-1990 normal big or bigger altho the fan blades are motor/vehical persific
if that helps
normal 1300cc-2200cc big 2000cc-2600cc bigger 2400cc-4400cc petrol
al deisels are the bigger ones
the over lap in the petrols are for the auzzie & the likes modles were they have sun
there was also a 6 bolt plate used for a short time from 80-84 not sure on what tho
if that helps
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
