wheel lock light gen 1 pajero
Posted: Wed Sep 05, 2007 9:36 am
by slow200sx
what does the green light saying wheel lock mean? is it the lock for centre diff?
Posted: Wed Sep 05, 2007 3:06 pm
by allovermud
is it on the truck diagram between rev counter and speedo? i think it mite have something to do wiht the hubs?
Posted: Wed Sep 05, 2007 3:14 pm
by Swaney
wheel lock light means that your automatic hubs are locked.
should be on the bottom row of lights on your display (was on mine till the bulb blew). The 4WD light (has a pic of 4 wheels and the t/box) means that the transfer case is locked and it is in 4WD mode.
to disengage the wheel lock light u have to be in 2WD and reserve back a few meters which turns the auto hubs off.
Posted: Wed Sep 05, 2007 6:02 pm
by slow200sx
thanks for that, can i change from auto to manual hubs? only thought that when decending a steep hill the auto hubs click out and are not locked and the back are only working. my terrano use to unlock when decending and once i put manual locking hubs on it was all fours working full time.
how do i lock the centre diff is there a way thats easily changable?
Posted: Wed Sep 05, 2007 6:08 pm
by NJV6
Hi, your gen 1 doesn't have a centre diff. Its the same as a Hilux etc, move the lever and your in 4WD.
You can get manual hubs. You need 25 spline ones, I'm sure AVM or Aisin ones are available. If you are going to be doing a bit of 4WDing with it then they are a wise idea.
NJ
