Factory Hooks Vs Rated Hooks
If you have a truck with factory hooks installed, I would be inclined to think that the hooks that are used would be sufficient to pull the truck out of any problems it might encounter... i'm sure that the manufacturer of the vehicle would take into consideration the weight class of the truck and 'rate' the hooks accordingly (therefore avoiding any nasty lawsuits).
Perhaps all of this is hogwash!, maybe it's best to just rip of those factory hooks and fit rated hooks instead.
Obviously if the vehicle is modified, you would not want to trust the hooks installed and then of course install rated hooks.
What's your opinion?
Have you ever imagined a world with no hypothetical situations?
OH GOOD LORD.............. JEEERRRRRRRRRRRRYYYYYYYYY!!!!!!!!! COME QUICK :shock:
My 2c's, rip off the factory ones and put on one's that you KNOW are rated.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
This has already been discussed in depth see
http://www.offroadexpress.co.nz/modules.php?name=Forums&file=viewtopic&t=5470
or just ring Jerry and get him to give you his 12 hour lecture over the phone
(021) 02388443
(021) 02388443
hehe, there's nothing like a towhook discussion to get people posting
still no sign of Jerry though... perhaps he has come down ill or something and can't make it to the computer
Ok, before anyone 'freaks out' about having me on any trips with them, I'd like the chance to state that 'I don't have factory hooks!'
I did notice with Daisy's hooks that it was the mounting, or the way it was mounted, that caused it to fail...not the actual hook itself, would this be a fair assumption?
So my original statement/question stands!, Assuming that the factory hook is assumingly rated for that weight class of vehicle and is mounted appropriately to the chassis using suitable bolts and plates, can it be trusted?...
It brings up another issue of if you 'swap' your factory hook for a rated hook (using the same mounting) arn't you actually in a worse off position? the mounting would most likely fail before the rated hook!
I like the idea of having standards in place for ORE trips (well in fact any 4x4 experiences) but who is controlling this? who can you go to make sure that not ony the hooks you have are ok but also the mounting you have is also ok... as i'm sure you are all aware, not all trucks are created equal and there are subtle differences between how and where hooks are mounted.
3
3
PR wrote:This has already been discussed in depth see
Ditto
The important thing you need to realise about rated recovery hooks is they that are designed to "open" when overstressed.
This will allow the rope/strop to fall free of the hook, where factory ones may break the hook off, making a leathal projectile, or cause serious damage to chassis etc where it is mounted
The factory tow hooks should be used as that, TOW hooks, not recovery hooks.
The mounting is just as important, a poorly mounted rated hook can be just as deadly as a weak factory hook.
- Steve_t647
most factory hooks are refered to in manuals as tie down hooks, US manufacturers have a rateing on them for a %age of the spring rate (found on a us forum, cant find again).
You can do whatever you want but you risk being handed a shovel to dig yourself out and risk having it break and smash someones window or pannel work or worse.
Me I got hooks and I will mount them upright.
Ok I'm here...... right who needs sorting out.....sound like I'd better come down there and give the 12hr lecture in person
HAHAHAHA nice windup
IN MY PERSONAL VIEW
The mounting is important when fitting them, all trucks are different so the agreed standard/protocol on ORE trips seems to be that the trip leader checks them and the mounts at the start of the trip and the person doing the recovering should check them as well.
Some clubs do regular safety checks, others don't...last time I suggested that IN MY PERSONAL OPINION
Disclaimer: the above was a suggestion only IN MY OWN PERSONAL OPINION
Universal Disclaimer
This product is meant for educational purposes only. Any resemblance to real persons, living or dead is purely coincidental. Void where prohibited. Some assembly required. List each check separately by bank number. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Postage will be paid by addressee. Subject to CAB approval. This is not an offer to sell securities. Apply only to affected area. May be too intense for some viewers. Do not stamp. Use other side for additional listings. For recreational use only. Do not disturb. All models over 18 years of age. If condition persists, consult your physician. No user-serviceable parts inside. Freshest if eaten before date on carton. Subject to change without notice. Times approximate. Simulated picture. No postage necessary if mailed in the United States. Breaking seal constitutes acceptance of agreement. For off-road use only. As seen on TV. One size fits all. Many suitcases look alike. Contains a substantial amount of non-tobacco ingredients. Colors may, in time, fade. We have sent the forms which seem right for you. Slippery when wet. For office use only. Not affiliated with the American Red Cross. Drop in any mailbox. Edited for television. Keep cool. process promptly. Post office will not deliver without postage. List was current at time of printing. Return to sender, no forwarding order on file, unable to forward. Not responsible for direct, indirect, incidental or consequential damages resulting from any defect, error or failure to perform. At participating locations only. Not the Beatles. Penalty for private use. See label for sequence. Substantial penalty for early withdrawal. Do not write below this line. Falling rock. Lost ticket pays maximum rate. Your canceled check is your receipt. Add toner. Place stamp here. Avoid contact with skin. Sanitized for your protection. Be sure each item is properly endorsed. Sign here without admitting guilt. Slightly higher west of the Mississippi. Employees and their families are not eligible. Beware of dog. Contestants have been briefed on some questions before the show. Limited time offer, call now to ensure prompt delivery. You must be present to win. No passes accepted for this engagement. No purchase necessary. Processed at location stamped in code at top of carton. Shading within a garment may occur. Use only in a well-ventilated are. Keep away from fire or flames. Replace with same type. Approved for veterans. Booths for two or more. Check here if tax deductible. Some equipment shown is optional. Price does not include taxes. No Canadian coins. Not recommended for children. Prerecorded for this time zone. Reproduction strictly prohibited. No solicitors. No alcohol, dogs or horses. No anchovies unless otherwise specified. Restaurant package, not for resale. List at least two alternate dates. First pull up, then pull down. Call toll free before digging. Driver does not carry cash. Some of the trademarks mentioned in this product appear for identification purposes only. Record additional transactions on back of previous stub. Unix is a registered trademark of AT&T. Do not fold, spindle or mutilate. No transfers issued until the bus comes to a complete stop. Package sold by weight, not volume. Your mileage may vary. This article does not reflect the thoughts or opinions of either myself, my company, my friends, or my cat. Don't quote me on that. Don't quote me on anything. All rights reserved. You may distribute this article freely but you may not make a profit from it. Terms are subject to change without notice. Illustrations are slightly enlarged to show detail. Any resemblance to actual persons, living or dead, is unintentional and purely coincidental. Do not remove this disclaimer under penalty of law. Hand wash only, tumble dry on low heat. Do not bend, fold, mutilate, or spindle. No substitutions allowed. For a limited time only. This article is void where prohibited, taxed, or otherwise restricted. Caveat emptor. Article is provided "as is" without any warranties. Reader assumes full responsibility. An equal opportunity article. No shoes, no shirt, no articles. quantities are limited while supplies last. If any defects are discovered, do not attempt to read them yourself, but return to an authorized service center. Read at your own risk. Parental advisory - explicit lyrics. Text may contain explicit materials some readers may find objectionable, parental guidance is advised. Keep away from sunlight. Keep away from pets and small children. Limit one-per-family please. This device complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) this device may not cause harmful interferance, and (2) this device must accept any interference received, including interferance that may cause undesired operation. No money down. No purchase necessary. You need not be present to win. Some assembly required. Batteries not included. Instructions are included. Action figures sold separately. No preservatives added. Slippery when wet. Safety goggles may be required during use. Sealed for your protection, do not read if safety seal is broken. Call before you dig. Not liable for damages arising from use or misuse. For external use only. If rash, irritation, redness, or swelling develops, discontinue reading. Read only with proper ventilation. Avoid extreme temperatures and store in a cool dry place. Keep away from open flames. Avoid contact with eyes and skin and avoid inhaling fumes. Do not puncture, incinerate, or store above 120 degrees Fahrenheit. Do not place near a flammable or magnetic source. Smoking this article could be hazardous to your health. The best safeguard, second only to abstinence, is the use of a condom. No salt, MSG, artificial color or flavoring added. If ingested, do not induce vomiting, and if symptoms persist, consult a physician. May cause any of the aforementioned effects and/or death. Articles are ribbed for your pleasure. Possible penalties for early withdrawal. Offer valid only at participating sites. Slightly higher west of the Rockies. Allow four to six weeks for delivery. Must be 18 to read. Disclaimer does not cover misuse, accident, lightning, flood, tornado, tsunami, volcanic eruption, earthquake, hurricanes and other Acts of God, neglect, damage from improper reading, incorrect line voltage, improper or unauthorized reading, broken antenna or marred cabinet, missing or altered serial numbers, electromagnetic radiation from nuclear blasts, sonic boom vibrations, customer adjustments that are not covered in this list, and incidents owing to an airplane crash, ship sinking or taking on water, motor vehicle crashing, dropping the item, falling rocks, leaky roof, broken glass, mud slides, forest fire, or projectile (which can include, but not be limited to, arrows, bullets, shot, BB's, shrapnel, lasers, napalm, torpedoes, or emissions of X-rays, Alpha, Beta and Gamma rays, knives, stones, etc.). Other restrictions may apply.
This supersedes all previous notices.
Jerry, you left out the most important instruction from your disclaimer:
"this side to enemy" - applies to Nissans as well as claymores - not so sure of Prados tho...
On the hook thing, I've broken the captive nuts on the back of my Patrol, replaced those (and 10mm plates, crush tubes,etc), then bent the rated bolts, then straightened a rated hook. I'd say it comes down to common sense (I've not tried that yet), and not getting TOO energetic on the snatches - you can bust anything if you try. The "rules" are about minimising the damage if/when you do, not about guaranteeing something's safe - imho.
disclaimer: sosume.
disclaimer: sosume.
.I like the idea of having standards in place for ORE trips (well in fact any 4x4 experiences) but who is controlling this? who can you go to make sure that not ony the hooks you have are ok but also the mounting you have is also ok... as i'm sure you are all aware, not all trucks are created equal and there are subtle differences between how and where hooks are mounted
As with all trips it is up to the trip leader to scrutineer trucks and drivers for trip suitability.
Thats some serious forces that you have thrown through your chassis!!
Just get a lighter truck??
Or learn to use a winch
Al
