35'' on my safari
35'' on my safari
Got a set of 35x12.5x15'' wrangler mtr's that im puting on my safari. Have got a 50mm body lift & a 60mm spring lift. Is there eneything i need to take off or cut out befor i put them on?
Just got my new 35'' fitted onto my new 15x8'' rims, then went to put them on the truck and found out thay dont fit
I found out that the hole in the center of the rim is 108.8mm insted of 110mm. Im told by the tyre guy that it is a manufactering stuf up and they will fit on a toyota hub but not a nissan hub. Not shaw of brand of rim but they are the standerd white steel 15x8'' rims with the blue and red pin stripe around them. Had to take them to my engenear to get them sorted. So try your new rims befour you buy toyota and nissan guys
