solid axle
Posted: Sat Sep 08, 2007 7:14 am
by zukmeista
Did any quads come with a solid axle :?:
Posted: Sat Sep 08, 2007 9:31 am
by Mikey
At the rear or the front? - plenty of ATVs have a solid rear and a independent front. Although a lot are now going fully independent :?
Posted: Sat Sep 08, 2007 10:10 pm
by zukmeista
f&r
Posted: Sat Sep 08, 2007 10:34 pm
by petefj40
Mikey wrote:At the rear or the front? - plenty of ATVs have a solid rear and a independent front. Although a lot are now going fully independent :?
Mines Fully independent. Has a solid rear axle. Thought most quads were.
Here's the specs for it.
ATV Type : Utility Quad Bikes
Engine
Engine Detail : 800cc, 4-stroke, V-twin, liquid cooled, 4-valve OHC
Engine Capacity : 800 cc
Valve Spec : 4-valve OHC
Type : 4-stroke
Cooling : liquid-cooled
No of Cylinders : V-twin
Bore / Stroke : 91 mm x 62 mm
Ignition : Electric
Torque : 73 Nm @ 5,500 RPM
Gearbox
Transmission : CVT, sub-transmission with high, low, park, neutral & reverse
Final Drive : Selectable 2x4/4x4 shaft driven with Visco-Lok front differential
Fuel
Fuel System : EFI, 46mm Throttle Body, 2 Siemens VDO injectors
Fuel Tank Capacity (Gal) : 5.3 gal.
Fuel Tank Capacity (Liters) : 20 liters
Dimensions and Weight
Length (Inches) : 86 in
Width (Inches) : 46 in
Height (Inches) : 45 in
Seat Height (Inches) : 34.5 in
Ground Clearance (Inches) : 12 in
Wheelbase (Inches) : 51 in
Dry Weight (Lbs) : 597 lb
Length (mm) : 2184mm
Width (mm) : 1168mm
Height (mm) : 1143mm
Seat Height (mm) : 876mm
Ground Clearance (mm) : 305mm
Wheelbase (mm) : 1295mm
Dry Weight (Kg) : 270.8 kg
Suspension, Brakes and Tires
Suspension - Front : RS type double A-arm, Forged Aluminum upper arm with 9 in (229 mm) travel
Suspension - Rear : RS type TTI independent with 10 in (229 mm) travel
Brakes - Front : Dula hydraulic discs
Brakes - Rear : Inboard hydraulic disc
Tires - Front : 25 x 8 x 12 in
Tires - Rear : 25 x 10 x 12 in
Towing Capacity
Towing Capacity (Lbs) : 1300 lb
Instrumentation and Lighting
Instumentation : Multi-function gauge: Speedometer, tachometer, odometer, trip and hourmeter, fuel, gear position, 4x4 indicator, diagnostics, auto shut off
Lighting : 4 fender mounted Projector Beam headlamps (60W) with tail light / brake light - EC approved, 4 flashers (EC version only)
Posted: Wed Sep 12, 2007 7:00 am
by zukmeista
solid axles front and rear :roll:
Posted: Wed Sep 12, 2007 1:47 pm
by petefj40
zukmeista wrote:solid axles front and rear :roll:
Nah. Makes it to hard to turn fast round corners. I like em locked in the front only when i need it. The front Visco locking system is awesome!!!! :D
Posted: Wed Sep 12, 2007 1:56 pm
by fweddy
yeah mine's solid front and rear :oops: well...
Posted: Wed Sep 12, 2007 5:12 pm
by petefj40
fweddy wrote:yeah mine's solid front and rear :oops: well...
Hey that looks in mint condition!
Posted: Wed Sep 12, 2007 6:18 pm
by fweddy
Actually I don't own that particular one any more, traded it on a more mint one!
People are always quick to jump up and say they are dangerous things - and to a certain extent they are - esp on hills but I would rather that than a quad in many situations. Its better than a 2x4 quad for traction and I have had it through mud holes that two 4x4 quads got stuck in. Its lighter and much more positive. Was using the neighbour's zuki quad the other day and it was scary to go very fast as the steering is loose but sensitive. The ATC can get up to about 70kms and still feel safe. And you can go round with one rear wheel off the ground. I'd say they are better for stunt riding than any farm set-up quad.
This is my current one - not much different to look at. Some of the most fun I've had on 2, 3 or 4 wheels would be this in the snow!
Dog is absolutely nuts on the bike!
Posted: Wed Sep 12, 2007 6:31 pm
by petefj40
I'd prefer one of those V8 trikes myself. They're cool. No good in the mud tho. :lol:
I've had my Renegade 800 Quad in the deep mud were all the other quads get stuck and never had any problems. Feels safe as at top speed to. (125ks) 8)
