Think i need lift now
What to do next to lift ??
Poll ended at Tue Sep 25, 2007 6:31 pm
SOA
13
59%
Body lift
4
18%
Spring lift
5
23%
Total votes: 22
Armourguard
Post by Armourguard »
Just got the 40 back from getting tyres fitted :lol: but it looks like i may need to lift :?
Any feedback on body lifts pros and cons and same with SOA would be appreciated :D
"Owning a 40 is almost like having an ugly child, with a really good personality."
MAHINDRACJ4A
Post by MAHINDRACJ4A »
the back looks like it rubs on the sides ??
maybe re arch the back wheel guard so its like rounder, and do you want to have a lift for just the fact because u put bigger tyres on ? or is there another reason iswel ?
1977 Mahindra CJ4A - 1GGTE 260hp Supra Engine - 3" Lift
Armourguard
MAHINDRACJ4A wrote:the back looks like it rubs on the sides ??
No it doesnt rub at present but thats just road running, abit worried i might stuff things (guards) when i start heading offroad and it starts to flex
niblik
Post by niblik »
soa...
why? cos ya can... :twisted:
really depends what ya wanna do with ya 40...?
Steve_t647
Post by Steve_t647 »
SOA as you have almost everything you need and the standard soft flexy springs will not make it much more unstable than a spring lift.
Best thing is you don't end up with a harsh ride on new springs and have all your fillings fall out.
gazthedoc
Post by gazthedoc »
Go the SOA, cheap as chips and helps move any of the delicated bits above the diffs and axles, I would get a high steer kit as well though, just looks nice and tidy
turoa
Pyro Junior
Post by turoa »
gazthedoc wrote:Go the SOA, cheap as chips and helps move any of the delicated bits above the diffs and axles, I would get a high steer kit as well though, just looks nice and tidy
Cheap as chips my ass. $1050 for a jafa high steer set up. You can fit 35's under a 40 by just cutting the guards. Then you dont have some idiotic sized lift. It wont fluff around on the roads either. Then you have to modify the spring perches, get new brake lines, new shocks, modify the driveshafts, cut and turn the front axle.
My vote is cut the guards. It also looks better when its low. Ever wonder why the trials guys have wide and low vehicles?
Steve_t647
Turoa look at the springs they are the standard toyota ones or so close to flat it wont matter.
I agree if the truck had a spring lift lifting it further would make it unstable give drive line issues but in this case are only going up the height of the diff, you would still rub on compression on the inner guards even with a SOA and such a clean 40 cutting it may not be the owners first choice.
It also helps with enging sump clearance and a lot of other issues. Not to be done lightly it is not as simple as replacement springs but bang for buck you cant really beat it.
BTW That is a really clean 40
warlord225
Post by warlord225 »
I voted, spring lift, but thought about it, and personally I would go for a body lift.
Although I do agree with turoa, about the wide low vehicle, I don't agree with cutting such a clean 40.
atleast with a body lift, its removable, you choose how much lift you want, and it won't cost the earth or rattle your fillings out.
And remember, all problems can be solved with difflcoks
muddy
Post by muddy »
I'm with Turoa! Cut the guards. Unless you're really fussy about keeping it nice & original (in which case you won't want a lift anyway), it's the cheapest & most effective way to fit bigger tyres. Scrubbing the inside of the guards will happen under articulation regardless of what lift you do. The only way to stop it is to widen the wheel track by spacers, rim offset, or 60 series rear end. If you lift it - you definitely want it wider or you'll scare yourself with how "tippy" it feels.
niblik
Post by niblik »
i run some 36" tsl's that i just found laying around in a gutter in brighton on my sua std 40.. ole rusty..
no rub as long as ya trim.. dont need to go nuts trimmin either.. could definitely be the cheaper option for now?
mudlva
Post by mudlva »
cut the guards keeps the truck center of gravity down, will help when climbing out of those nasty old rutts and stuff
cheers mudlva
Armourguard
Yeah i was thinking of cutting guards 8) but would anyone recomend moving rear axle back on the springs about 30mm :? just means redrilling springs
Steve_t647
Um drilling spring steel is not a quick job with normal tools :wink: Be quicker to send them out to be re drilled
Smurf
Post by Smurf »
Isn't there a spring flip (end for end) that moves your diff back?? Niblik may have done it to his wagon??
a wee bit of guard rub never hurt anyway :thumright:
niblik
Post by niblik »
spring flips doable, but ya want the military wrap to face the front still, so a spring or two may need drilling, then theres the driveshaft length...
easy though.. :wink:
