Mal
Does 2 batteries = 24 volt?
I'm guessing not in my case (93 Prado KZJ78). Someone has told me that a relay sends 24v to the starter, but the rest of the system will be 12v. The dash dial shows a max of 16 or 18v, but just want to double check this before I go and buy any electrics
Mal
Mal
wjw wrote:All the Prados I've seen are 12 Volts. But some have duel batteries, but still 12V
It would be a duel if the batteries were fighting with each other for the charge.
Anyway, a lot of people run dual battery system for the winch. As long as the batteries are connected in parallel, they will remain 12v. If you connect them in series, then you have 24v (not good if your electrics are all 12v).
