Windscreen removal on a '89 Bighorn also want a new one
Posted: Sun Sep 16, 2007 12:43 pm
by dazza85
Has anybody removed a windscreen from a '89 bighorn ??
I have to take the screen out to get the head lining out to deal to a large crease and some rust in the roof.
Can you do it yourself of is it better to get the professional to do it ??
Also does anyone have one spare as mine has a big crack in it and I think that it will break when removed.
Posted: Sun Sep 16, 2007 7:50 pm
by H2OLOVA
Sounds like a job for a professional
And if the screen your taking out is already cracked then you're wasting money putting it back in again. Surely you can get the hood lining out ?? Supralux might have some pointers on hoodlining removal. Give me a yell if you want the screen done.
Posted: Sun Sep 16, 2007 7:54 pm
by Goose
H2OLOVA wrote:Sounds like a job for a professional
Better check his location before offering your services.......
Posted: Sun Sep 16, 2007 8:04 pm
by H2OLOVA
Good point
Maybe a bit far for me.
Posted: Sun Sep 16, 2007 8:46 pm
by dazza85
So you are saying that I should not worry about saving the screen seeing as it has a big crack across the top ... that being the case I should have a go at popping it out myself
The lining is glued under the rubber like this ...
Once it is out I have a bit of work to do once the panel beaters have done their bit as I want to fit my radios up there out of harms way... hopefully
Thanks for the offer of a hand ... If I lived down that way I would take you up on it
Posted: Tue Sep 18, 2007 11:49 pm
by fish
i need to put a new wind screen in too...
is it worth trying it on my own or paying 70 bucks to get it done?
Posted: Wed Sep 19, 2007 7:37 am
by MudBum
Sorry to say boys these are the worst rubber fitted screens ever made.If you have a factory screen (ie never been replaced b4)Isuzu glued them into the rubber
After nearly 20 yrs service the rubber gets brittle and wont handle the abuse to get it out nicely.We mostly recommend a new rubber as well,however if it has been out b4, someone has done the hard work all ready and it should be ok. Just be warned $70 bucks for a professional to do it would be well worth the moolar...
Posted: Thu Sep 20, 2007 12:46 am
by fish
thanks for the warring
ill just get them to do it and hold him to the 70 buck quote...
Posted: Thu Sep 20, 2007 1:05 am
by Azza
I poked and prodded my windscreen rubbers for weeks before deciding to bite the bullet and got someone 'professional' to do the job, best decision I made... worth every penny I paid, they did a really good job and I didn't even have to get my hands dirty
I had lots of problems trying to source a secondhand windscreen, they were either not available or were already 'cracked' due to someone (non-professional) trying to remove it.
To remove the windscreen, i wouldn't worry about getting a pro to remove it, vent your frustrations with a large hammer
To replace, buy new! (they're pretty cheap, even compared to secondhand) and get a pro to install it!
