The springs are 50mm raised coils - Maxitrac brand. The shocks in the front are standard Maxitrac and were slightly longer than stock from memory. They replaced the KYB factory electric adjustable ones.
The fun was in the back - there is no listing in the Maxitrac models for a pin/eye rear shock so the solution was a slightly modified Hilux front shock, which has more travel than a standard Paj rear, and almost the same mounting - just a little packing in the bottom mount to make it the same width, then bolt on as normal at the top... I suspect the non-adjustable shock models have eye/eye as thats the only listing I had.
...which is where the fun began - as I'm sure Debs will attest to since she sat outside reading her book while I left small DNA samples all over the suspension and sat telling god all about where Mitsi could stick there clever system for attaching shocks. It was from trying to get the last nut off the last shock
bloody stupid Mitsi design... Spanners, crowbars, hammers, air hammers, cold chisels and finally a grinder... mutter mutter...
Anyway, all in and cranked up and on new 32" muddies the truck actually looked really good (for a Mitsi
) when it left - I'm off to check the photos myself to see what happened to it...
Steve
