33x12.5x15 What Rim Size ??
MAHINDRACJ4A
Post by MAHINDRACJ4A »
Hey
Was Thinking today as i'll need new tyres about going to 33's so what size rim width would i need ?
i think the rims i have now are either 7" or 8" wide
also the bigger size would give me more speed at a lower rpm
And anyone know if these will fit my mahindra with out a lift ? i dont plan on going hardout offroading maybe just a shiny trip but thats about it
1977 Mahindra CJ4A - 1GGTE 260hp Supra Engine - 3" Lift
NJV6
Post by NJV6 »
HI there,
Most 4WDer's put 33's on 8 inch rims but I think 10 inch is recommended. They do tend to get more crap in between the rim & tyre with wider rims. If you were manily going to cruise and show it then go for some nice fat 10 inch rims.
When measuring your rims to see what they are, measure from where the bead sits not from outside to outside as this adds about 1 inxh to the overalll width.
I think you should get 33's on but not positive. It would certainly help your on road gearing considering factory is 600x16 which is about a 29'
MAHINDRACJ4A
yep, but where do i find some 10" wide rims ? i dont want white spoke rims, my stud pattern is 5x139.7 same as lot of suzukis
MAHINDRACJ4A
also would i be able to get 5x139.7 to 6 stud adaptor plates ?
or something like that or get rims redrilled ?
rim
hi put my 33x12.5'sx15 on 8's as the arrival of new 10's were a month away october i was told , and on 8's with low pressure i would pop the beads, well so far,
MAHINDRACJ4A
i wont be running low pressure as its more a road truck & real light shiny 4x4 trips
rangimotors
Post by rangimotors »
i was told on a lighter vechicle that 7inch rims would be sweet as
used to run 10" rims with 33s, but beads kept popping and getting shit in them.
changed to 8" rims and had less problems as they sit on there tighter.
now have beadlocks, so no probs at all now.
I would go with the 8" rims, and with that pcd you can find some sexy alloys too.
safangari
Post by safangari »
Running 33x12.5s on 10 inch rim means a lot of sidewall is exposed. Run them on 8s.
red-devil
Post by red-devil »
:oops: i run 33" 12.5 15 on 7" rims very tight to get on but i have neave poped the bead yet and i run 10 psi on some trips. today i was running 15psi in the mud with no probs
jono :)
MAHINDRACJ4A
skid wrote:I would go with the 8" rims, and with that pcd you can find some sexy alloys too.
lol where can i find some nice rims ? been looking for about 1year and am yet to find something that looks sexy haha
fweddy
Post by fweddy »
Was speaking to a tyre shop recently. He suggested 7 or 8 inch. The wider you go the more likely you are to pop off the rim, but also the more tread it allows to lay on the road. I have 8" and they fit and run well so far.
Smurf
Post by Smurf »
I'd run 33/12.5 inch tyres on 8 inch rims, unless you need to be on a specified rim width for cert. Most tyre manufacturers will recommend a rim size of 10 inches.
Hankook recommend 8-10 inch rims for their 33/12.5/15 tyres.
sig
Jeep Jeep
Post by sig »
8" rims are pretty good for 33", if you go wider they look cool but pop the beads a hell of a lot easier offroad. i run 35" as road tyres on 8" rims and are nice on the road without 2 much sway ( thats my 2 cents worth anyway)
MAHINDRACJ4A
tyre popping off shouldnt be too much of a problem, look at all the drifters who run hard out streched out tyres, plus im not going to do offroad much maybe a shiny trip but thats all, and on road its not going to be driven much either
sig
Jeep Jeep
Post by sig »
on road 10" look way cooler
depends wot you're looking for. heres some that you can get from any good tyre shop................
MAHINDRACJ4A
have u seen the price tag on them ? + they are all ex-usa, looking for second hand
tallsam66
Post by tallsam66 »
Id of thought the width of the tyre ie 10.5 or 11.5 or 12.5 would what determines the rim width...i cant see why a larger diameter ie 31,33,35 etc makes a difference.
MAHINDRACJ4A wrote:have u seen the price tag on them ? + they are all ex-usa, looking for second hand
http://www.trademe.co.nz/Trade-Me-Motor ... 249510.htm
Smurf
Post by Smurf »
Another option is to keep your rims and use 33/10.5/15 tyres.
MAHINDRACJ4A
My Stud Pattern Is 5x139.7 not 5x114.3
that makes it a lot harder to find wheels then.
good luck
hope when you find some, they look sexy as hell
xj
Post by xj »
thanks for promoting my auction there skid :lol:
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Return to “Tyres”
