Help with SD33T injection problems
nz4x4
Post by nz4x4 »
Hoping one of you guys can help me out. Have an SD33T in my MK Patrol.
Suspect that i have run out of diesel (no guages working at present) and truck won't start. Have put 20l of diesel in and bled the fuel system upto the injection pump bleeder screws (fuel filter first, then injection pump bleeder screws) All ok there. The problem is when i crack the injectors and crank the engine no diesel is comming through :?
Any ideas what to do next? If you need more info just ask
paule
Post by paule »
There is a fuel shut off solenoid on pump. It needs ign voltage to allow disel into pump.
