SJ410 Fuel pump issues
For all Suzuki related topics
UBZ
Post by UBZ »
have been helping a mate fix up his SJ410 standard 1L engine and cant get any fuel to the carby
Have replaced inline filter, blown out the fuel lines, replaced all the hoses, flushed the fuel tank.
Pulled off the fuel pump and stripped it down , looked all good so reassembled
Still no fuel out of the pump :(
Any ideas ,are we missing something simple :? :?
Looks like the next step is to buy a new fuel pump
mercutio
Post by mercutio »
on my little suzuki car with a mechanical fuel pump i was having trouble getting fuel to the carb i ended up undoing the fuel pump and with the hoses still connected i manually pumped the pump i think i cracked the banjo bolt going into the carb as welll i just pushed the lever against something a few times until fuel came out of the banjo put it all back together and all good now
my 4wd is not a truck
UBZ
Post by UBZ »
definably worth a try . :)
2 bolts is better than a new pump
UBZ
Post by UBZ »
Cheers Mercutio
Pulled out the pump this evening after work and gave it a few pumps until it primed . Bolted it back in and she fired first time..
Took about 10mins all up. :) and saved $150 :D :D
Very good to know it wont prime by just turning the engine over.
mercutio
Post by mercutio »
glad to be of assistance :D :D
Return to “Suzuki”
