1HDT Oil pressure
Posted: Fri Sep 28, 2007 9:17 pm
by stompin
Hey guys
I just had my the engine in my cruiser rebuilt (1hdt), just wondering what sort of oil pressure i should expect?
I dunno if the gauge if fuckd, or if somethings up because the gauge seems to change depending on idling/accelerating/etc. So i am going to mates tomorrow to put an after market gauge on to test it. Just wondering what i should expect.
brad
Posted: Fri Sep 28, 2007 10:30 pm
by wopass
it will read lower at idle than at 3k rpm,about 1/4 at idle is normal for a well used 1hdt, or a bit more for a fresh one. at 3k rpm it should read about halfÃsh..... from memory.
so the more revs you pull the higher the pressure should be
Posted: Sat Sep 29, 2007 4:15 pm
by adogg
i would check it with an aftermarket gauge but the factory gauge is anything but accurate its there for novelty factor more than anything
Posted: Sat Sep 29, 2007 7:29 pm
by stompin
adogg wrote:i would check it with an aftermarket gauge but the factory gauge is anything but accurate its there for novelty factor more than anything
The factory gauge i had repaird the other week but i still think its mis reading the oil pressure, I was going to use an after market gauge to check i, went to my mates work to do it today but due a rather bad haing over nothing was achieved.. So ill drop it in there this week for a 1000km oil change and they can check the oil pressure, just paranoid after droping a few grand on engine rebuild.
Posted: Sat Sep 29, 2007 8:58 pm
by Smurf
Does the motor still have running in oil in it? That may give you a lower oil pressure as it tends to be thinner.
I don't know if many people still use running in oil these days or not though???
