my VX has a noisy speedo in the dash.
I have had it apart and squirted CRC down the cable, but its still noisy.
someone give me other ideas on how to fix it.
SKID
noisy speedo
- skid
- Tyre Man
noisy speedo
Re: noisy speedo
skid wrote:my VX has a noisy speedo in the dash.
SKID
disconect it
i used to have this problem on one of the trucks i used to drive at work
i used crc but sprayed a little bit in the back of the speedo it seemed to do the trick
my 4wd is not a truck
- truck-fixer
Hey just a tip on lubricating speedo/clutch/brake cables or whatever cable it may be. Get some graphite powder into a squirty bottle, fill the bottle with CRC, give it a shake to mix it up then spray it down the cable.
Because CRC dries up after a short while this solution will wash the Graphite down the cable and when the CRC dries up the graphite will stay there to lubricate the cable for much much longer.
Store that in the memory file for later.
truck-fixer wrote:Hey just a tip on lubricating speedo/clutch/brake cables or whatever cable it may be. Get some graphite powder into a squirty bottle, fill the bottle with CRC, give it a shake to mix it up then spray it down the cable.
nice one thanks for that it is a great idea
- truck-fixer
