hilux and surf diff swaps?
i have an 85 hilux twincab yn65 with tired sounding diffs
rear has a lot of backlash front one goes grrr when in 4wd
also have a 88 surf ifs in good cond but dead engine
can i swap the whole rear diff and u bolts/plates ? is it wider?
where can i find the ratios?without dismantling?
will my current rear diff head maybe lsd? fit into my front beam axle housing?
ok thats enough questions for a start
any site suggestions for this info welcome
- muddy_munke
Am currently in the process of doing the swap for the wider rear axle from a surf. The best option is to do the swap and at the same time do the disk brake conversion. all up probably only costs about $150 for the parts. Cheap as chips and well worth it.
And yes, your diffheads do bolt into the front axle.
Cheers Daniel
Cheers Daniel
some light reading
http://offroadexpress.co.nz/modules.php ... pic&t=1453
http://www.offroadexpress.co.nz/modules ... pic&t=2008
http://www.offroadexpress.co.nz/modules ... pic&t=3543
http://www.offroadexpress.co.nz/modules ... ic&p=51039
http://www.offroadexpress.co.nz/modules ... pic&t=1147
http://www.offroadexpress.co.nz/modules ... ic&p=51055
yes light reading
scoped most of them and most of the other links to hilux mods
i can almost quote the fricking lvv code from memory too
and every rover v8 tech site on the net
thats why this site is soo good
people actually go yes i did that it works ya need to change these bits too
thanks for the links
Most NZ new YN Hiluxes were 4.88 diffs. Your Surf one will be 4.3 which will stuff your gearing all to hell... don't do it, you'll hate it offroad...
4.88's are hard to find these days and getting pricey when you do, making it almost cheaper to go with 4.3's and just upgrade the engine to fix the gearing... not the answer you probably wanted, but there you go
Steve
Steve
sweet sounds like the go
might run these til they die
first on the list is lvv and plates
and then swap the whole rear axle for the width
and buy a 4.3 for the front
and keep the ifs discs for disc rear later on
and the steering box for a crossover sometime
anyone want a 2lt motor running on 3 cyl with good knockin noises
good turbo going cheap
located in nelson
located in nelson
