Has anyone here used it? Does it really work as well as the all the hype i've heard about it? and just how bad is the smell?
Az
Azza wrote:I'd like to do a bit of rust proofing to the underside of my truck, i've heard that Fishoilene works well to prevent rust, apparantly you can even drive in salt water on a regular basis and still have no problems.... but I also heard that if you use it your vehicle tends to smell like fish![]()
Az
Steve_t647 wrote:it is only when it is wet or very hot that it smells and if in the GGE it can get a bit wiffy.
fweddy wrote:yes true - lovely hot sunny day, picnic out with the classic and things get a little fishy![]()
but you don't mind the smell when you have taught yourself that that smell means preservation of body panels and chassis structure, reminds you of hard work passed and many memories!
Steve_t647 wrote:I think as a daily driver I would not use it around the exhaust
Steve_t647 wrote:Your exhaust can get a lot warmer than 100deg
DieselBoy wrote:Use Cavity Wax, fisholene is well out dated.
No fishy smell, easier to apply, doesn't melt in the sun, works better and lasts longer
Azza wrote:DieselBoy wrote:Use Cavity Wax, fisholene is well out dated.
So, just what is cavity wax?.... do you spray it on like fishoilene? or is it more like hair gelsounds like it could be messy to apply
