body lift need help escudo
i have got the body lift bolcks but cant get the old bolts out as it has double sikn floor as such how do i get around this thanks
you don't normally... you need extended studs with treads on inside of them...
like this:
from this site:
http://www.izook.com/tech/tracker/kicklift/bodylift.htm
have a look through this site also (use the search)
http://bbs.zuwharrie.com/content
it is possible to make the bolts up but gets a little dicey...
like this:
from this site:
