How to clean standed oil out of a LSD diff
Posted: Sat Oct 13, 2007 3:09 pm
by minefield
hi All,
I have just discovered that I have a LSD :D and that the last owners have been using standed oil . :(
what is the best way to clean out the old oil and clean the plates of the lsd Before I put in new oil.???
many Thanks
Graham :D
Posted: Sat Oct 13, 2007 3:40 pm
by PigFmr
hello
take out about 300mm of diff oil out and top it up 300mm of engine flush drive around a few days untill you have done 500 to 1000km, just before you drop your oil make sure the old diff oil is hot drain and replace with good oil i use redline or penrite, seen this on another site i use, a lot people do it and i have done aswell gives the plates a good clean
vince
Posted: Sat Oct 13, 2007 5:09 pm
by minefield
The red line / penrite Is this a oil or a cleaner
graham
Posted: Sat Oct 13, 2007 5:12 pm
by DaveM
minefield wrote:The red line / penrite Is this a oil or a cleaner
graham
These should be the oil, I assume any engine flush would do?
Posted: Sat Oct 13, 2007 5:17 pm
by minefield
I'm going to Try it tomorrow, Keep you informed
Graham
Posted: Sat Oct 27, 2007 11:15 am
by PigFmr
how did you get on ???
vince
Posted: Sat Oct 27, 2007 1:56 pm
by minefield
No good, I possible did not leave the cleaner in long enough, But i have rechecked it and wheels both turn the same way,
This time I'll make sure its in for a good 1000k's
Graham
Posted: Sat Oct 27, 2007 2:00 pm
by Petemcc
Both wheels should turn the same way with an lsd. they will go different directions with an open diff. (i assume you are meaning jack both wheels off the ground and spin one and see which way the other spins?)
I was under the impression that the oil doesnt make too much difference.
Pete
Posted: Sat Oct 27, 2007 2:45 pm
by TJ
Most diff oils now have the additives already. Without that LSD would have excessive wear and tear. Just drain it, clean internals with brake clean spray, let dry and refill with proper oil and additive. Its easier on a Jeep because we have to take the diff cover off to drain, so all internals are easily visible and accessible. I do this every year. Jeeps normally don't have drain plugs on diffs, just a fill hole.
Posted: Sun Oct 28, 2007 8:17 am
by minefield
One question I should ask, Now that I have discovered that I have a LSD
If the cleaner will not work, What is there in a LSD that would stop it working , There must be something in the LSD it's self that could have come adrift, But what !!! :(
Graham
Posted: Sun Oct 28, 2007 8:29 am
by turoa
minefield wrote:But i have rechecked it and wheels both turn the same way,
petemcc wrote:Both wheels should turn the same way with an lsd.
Sounds like it IS working if they are turning the same way. If it isnt then its not likely that you have an lsd. how do you know it is one? if you jack up one side and put everything in neutral, can you turn that wheel? if its very hard to turn it then you've got an lsd.
Even if the clutch packs are extremely worn out its unlikely that the wheels will turn different ways. It is my understanding that that is not how an lsd works (I am quite often wrong though).[/code]
Posted: Sun Oct 28, 2007 11:02 am
by minefield
Are the clutch pacts easy to replace,And are they easy'ly obtainable
Graham
Posted: Sun Oct 28, 2007 11:15 am
by turoa
minefield wrote:Are the clutch pacts easy to replace,And are they easy'ly obtainable
Graham
usually you take it to a diff place and they shim them up.
Posted: Sun Oct 28, 2007 11:50 am
by minefield
you are right, I'm still in the middle of setting the Nissan up so I may as well get it done properly
Graham
