alrighty.. the other day i went out to loburn and picked up a series 2a landrover p.o.s...
it has s.o.a with what i was told were parabolic springs, salisbury rear diff, landy front with range rover hubs and disc fronts.. ya can see the seats, roll bar, has a twin 2.5 exhaust all customed up block huggin headers, b & m shifter, shortened c4 auto, big arsed 4 core radiator (dunno what from, so dont ask.. ) trans oils cooler..
it also has a solid frame with mesh strip along the bonnet just in front of the windscreen.. engine coolin.. sweet.. thought since i'm chuckin a windsor in, i'll grab the tailgate off the 109 s2a i have and put that on the 88".. also on that tailgate there's a twin jerry can holder, so that'll help on the longer trips...
its been sittin outside unloved and unwanted for the last year.. so theres pieces like the exhaust and roll bar that have surface rust but sound as..
thought might be able to use this as a trials rig (could flop it and not worry, a 'sacrificial lamb' you might say..) i know its not perfect, far from it. but it'll be a bit of fun as rusty is too dodge to take out now...
till the 40 gets goin..
originally it came without a motor (last dude had spent 12 grand on his 302 and wanted to hang onto it..) and needed to source a 302 or 289...
what an interesting night.. started by accumulating a few bits throughout the day...
when it came time to strip crap off old engine and prep it for goin in the hole, there was only one good rubbered engine mount and even then that side was sort a bit of c-channel to bolt onto chassis side of mounts.. soooooooo after a quick call to butlers in stanmore road at 8:50pm, they said yep, got em, close at 9! nibs off racin on a mission to race across there in friday night traffic to get em.. and was successfull.. even managed to get a pair of them that were complete with the afore mentioned c-channel bit to mount em up fully..
then there was an interesting moment with the torque converter.. seems the torque donut thingy wasnt pushed in fully.. when tryin to turn over it didnt seem free, like it was bound up.. so when pullin the motor back out, h20 wiggled then pushed the torque thang in about 10mm...! so then swapped a spacer washer on the ring gear and chucked it back in the hole.. swish! in it went..
then after a bit of hookin up the wiring and muckin around with the remote oil filters, tried startin the sucker... no manifolds on either, just for that 'early 2am neighbourly' wake up call.
http://www.offroadexpress.co.nz/images/ ... ll_003.mov (p.s vid in 'quicktime' format)
till monday night...
just wanna say a might big thanks a heap! to mike, h20, chopper , mat, goose and westie.. heaps of help and thanks!
cheeky monkey...
who let him in here?
