Wanted: Manual 4wd Actuator - '88 LJ71 Landcruiser T/C
MNC
Post by MNC »
madaz068 wrote:Theres a guy up here Bruce that wrecks 70 series, if anyone wants his number i have it.
I'm having some issues fitting the vacum operated actuator between the chassis on my 40 series. So looking to replace it...
Has anyone got a spare manual 4wd Actuator off an '88 LJ 71 landcruiser Transfer case :?:
Cheers 8)
I've got a couple of Pajero ones that will do the job if you want them
I didnt think the LJ71's had a manual engaugement? You might have to find a 40 series split transfercase?
turoa
Pyro Junior
Post by turoa »
Im looking for something for manual 4wd aswell. The vacuum 4wd doesnt fit in my chassis. I have looked at a cruiser transfer, but would have to change the output shaft and front output housing.
I was thinking of making my own lever for it.
MNC
Post by MNC »
Jerry wrote:I've got a couple of Pajero ones that will do the job if you want them
Yip keen as, are the Pajero ones a match for the Prado T/C?
Will PM ya. Cheers, :wink:
Are you talking about the 2 12v vacuum switches when you mean actuater? cos thats what I think you mean :lol:
Jerry wrote:Are you talking about the 2 12v vacuum switches when you mean actuater? cos thats what I think you mean :lol:
nope he means the vacume diaphram on the side of the transfer case
MNC
Post by MNC »
Doh, dont think so...
4wd Actuator is the unit that bolts onto the side of the transfer case. A manual actuator connects directly to the 2wd, 4wd High, 4wd low gear stick.
A vacum unit has a small frisby like unit on the actuator which sits horozontally and is fouling the chassis in my case :(
MNC
Post by MNC »
Sadam_Husain wrote:nope he means the vacume diaphram on the side of the transfer case
Yeah, what he said...
sorry I thought you meant the switch :oops:
MNC
Post by MNC »
Jerry wrote:sorry I thought you meant the switch :oops:
No worries, Thanks anyway.
I'm pretty sure the t/c casings are different so it'll have to be a swap to a 40 series t/c to go fully manual selection
