Shaky brakes
Shaky brakes
My 89 70 series shakes like hell when i put the brakes on. I have changed the front brake pads and its still doing it. (they needed doing anyway). It shakes the steering wheel so im guessing its the front brakes causeing the problem. I had a good look at the rotors and they were pretty true so maby its the slave cylinders?
- Steve_t647
The kingpin bearings can also cause similar effects. I agree Jack the front of the truck up and wriggke the wheels see if there is any movement and remember 1 or 2 mm is a lot with the weight of the truck.
Also look at the wear pattern on the tyres if uneaven it could be a clue.
I suspect the rotors also but it is worth having a look for anything moving that could make it worse.
