70 series 12v diff lock motor in a 24v truck
GrahamN
Post by GrahamN »
Hi all,
does anybody out there know of a way to convert a 12v difflock actuator motor so it can run in a 24v truck?
There's got to be a way of doing this without spending a load of money...
Graham
Smurf
Post by Smurf »
Get your self a 24V to 12V converter to supply power for diff lock motor.
Would also give you a power supply for other 12V items. There may be a 12v circuit in your vehicle that you can tap into, as your stereo will most likely be 12V.
http://www.dse.co.nz/cgi-bin/dse.storef ... View/M9814
http://www.dse.co.nz/cgi-bin/dse.storef ... View/M9813
GrahamN
Post by GrahamN »
Thanks for the idea but I can't think how to make it work. The truck still has the 24v front locker in place and its run off the same diff ECU which stops me converting the power supply to the whole unit. The motor polarity is switched down the 2 wires depending on what direction it needs to run, to lock or unlock, which stops me running a dc 24v to 12v converter in line to just the motor itself (i think).
I'm going to buy a converter to run the other accessories though, as you suggest.
dazza85
Post by dazza85 »
Or there is the real simple way ....
Use this circuit ...
http://www.4x4wire.com/toyota/tech/electric_locker/
feed it via fuse from the battery that has it's negative terminal connected to the chassis.
[/url]
mercutio
Post by mercutio »
GrahamN wrote:Thanks for the idea but I can't think how to make it work. The truck still has the 24v front locker in place and its run off the same diff ECU which stops me converting the power supply to the whole unit. The motor polarity is switched down the 2 wires depending on what direction it needs to run, to lock or unlock, which stops me running a dc 24v to 12v converter in line to just the motor itself (i think).
another idea is to use the ecu to operate a pair of 24 volt relays and then run 12 volts to the other side of the relays and to the diff actuator if that makes sense
my 4wd is not a truck
GrahamN
Post by GrahamN »
Great advice guys! :D Thanks, I'll see what I can sort out but I reckon it will work with one of those solutions.
