Unfortunately my Nissan Mistral has recently developed a diesel leak while running. I thought I may he got away with the lower sulphur diesel because it is a 96, but apparently not.
Can anyone confirm whether they have one of the older VE rotary fuel injector pumps that are prone to leaking or whether it may be a different and hopefully less expensive problem to solve.
Thanks guys, your hep is much appreciated.
Mike
TD27 leaking diesel
- billyvanboheman
If it's TD27, then yes, it's Zexel VE rotary.
Apparently Milburn's are worth a try for a price.
You can probably get away with just replacing the top cover and throttle lever input seals, these can be done with the pump in situ, providing the pump on a TD27 is reasonably easy to access.
A decent garage should charge sweet FA to do this, compared to a full teardown and replacement of all the seals in the pump.
Once again, thanks Guys. THe wealth of knowledge and expirence on this site never fails to impress
meatc, Its good to hear it can be done at a reasonable cost because replacing them myself is just a bit past my skills.
and smurf182, I was hoping that would be the case;and that just a couple of seals would need to be changed as opposed to a complete overhaul.
Mike
Mike
- billyvanboheman
Of course it's all dependant on if it is a seal leak or not, but hopefully that's all it is.
Keep us up to date on how you go.
We have done as late as 96 TD27's for this leak, so chances are high that is what it is
