TD27 leaking diesel
Posted: Thu Oct 18, 2007 7:30 pm
by Mikey
Unfortunately my Nissan Mistral has recently developed a diesel leak while running. I thought I may he got away with the lower sulphur diesel because it is a 96, but apparently not.
Can anyone confirm whether they have one of the older VE rotary fuel injector pumps that are prone to leaking or whether it may be a different and hopefully less expensive problem to solve.
Thanks guys, your hep is much appreciated.
Mike
Posted: Thu Oct 18, 2007 7:58 pm
by aroma
work mate had leaky injector pump in 92 or 3 terrano took it to gainsbury aut in dyers rd had it fixed in a day and he said was good price (hes tight)
it is wof issue leaky pump fail wof thats how he found out belive it is common but could be wrong :?
Posted: Thu Oct 18, 2007 8:33 pm
by billyvanboheman
If it's TD27, then yes, it's Zexel VE rotary.
Apparently Milburn's are worth a try for a price.
Posted: Thu Oct 18, 2007 8:45 pm
by Mikey
billyvanboheman wrote:If it's TD27, then yes, it's Zexel VE rotary.
Cheers, Thanks for the help guys. Just wanted to be sure before I found someone to have a look at it. Will give Milburn's a call tomorrow.
Posted: Thu Oct 18, 2007 9:00 pm
by meatc
Had mine done a coupel of years back. Cost about $140. there was only about 30-40 bucks of seals but the inlet manifold has to come off to get access so the labour can get up a bit.
Posted: Thu Oct 18, 2007 9:01 pm
by smurf182
You can probably get away with just replacing the top cover and throttle lever input seals, these can be done with the pump in situ, providing the pump on a TD27 is reasonably easy to access.
A decent garage should charge sweet FA to do this, compared to a full teardown and replacement of all the seals in the pump.
Posted: Thu Oct 18, 2007 9:11 pm
by Mikey
Once again, thanks Guys. THe wealth of knowledge and expirence on this site never fails to impress :D
meatc, Its good to hear it can be done at a reasonable cost because replacing them myself is just a bit past my skills.
and smurf182, I was hoping that would be the case;and that just a couple of seals would need to be changed as opposed to a complete overhaul.
Mike
Posted: Thu Oct 18, 2007 9:14 pm
by billyvanboheman
Of course it's all dependant on if it is a seal leak or not, but hopefully that's all it is.
Keep us up to date on how you go.
We have done as late as 96 TD27's for this leak, so chances are high that is what it is :roll:
