as above. i need the passengers side steering knuckle off of a ln106 solid front axle hilux. ive stripped the thread that holds the caliper on
so can anyone out there help me out?
SMOKEY wrote:Drill and Tap the thread to take the next size bolt, you will then have to run the drill size for the bolt through the calliper. If you need drills and Taps give me a call.
Ph 3387202 or 0274318993.
FITZY.
hosehustler wrote:Yeah I have one off a solid axle surf, pretty sure they're the same, the only difference is the callipers and rotors, the knuckle is the same
