Towing a 4x4 landrover
landie
Post by landie »
Hi,im new to 4x4s i was just wondering if is ok to tow my s3 landrover?it's better than driving it to go bush bashing cause it rings its tits off at 60-70 kms on the open road plus it has no wof/reg.are there any tips that i need to know without shagging it? :? Any help would be mint :D
Steve_t647
Post by Steve_t647 »
You can put the gearbox in Nuteral or the auto in Park and put the transfer case in nuteral it should roll easily and you are off. Not sure what others have done or do Mile tows his and I think he uses transfer case nuteral too.
lilpigzuk
Tiger Balm
Post by lilpigzuk »
make sure freewheeling hubs are set too free, less drag if the front wheels arent turning front diff etc
Goose
Complete Plonker
Post by Goose »
Mike puts his in neutral in the transfer to tow it :wink: h2olova had a landy years back, he put free wheeling hubs on all 4 wheels 8) Unlock'em, and away you go, worked bloody good :D
"He who dies with the most toys wins!!"
niblik
Post by niblik »
on my rover i got rangie front hubs, so no manual hubs that i can unlock.. :?
gearbox in neutral and dont slow down too much otherwise tyres lock to the right.. :roll: makes life interesting..
H2OLOVA
Post by H2OLOVA »
Steve_t647 wrote:You can put the gearbox in Nuteral or the auto in Park and put the transfer case in nuteral it should roll easily and you are off. Not sure what others have done or do Mile tows his and I think he uses transfer case nuteral too.
Might be better to have an auto in neutral for towing
Steve_t647
We did it this way to ensure the transfer case was in nuteral if you have both in nuteral you can tow and still spin the output shafts etc on the auto his LR has the pump for the auto on the input shaft.
He wanted to be 100% on transfer nuteral this is why he did this, not sure if they all run this way. Mike may know.
niblik
Post by niblik »
come to think of it, mine was park and neutral when i towed it home.. i think? ehhhh... think much too coffee function well without. Image
Steve_t647
It depends on the Auto I would tow a 4wd auto the way I iindicated, transfer nuteral. A auto car I would remove the driveshaft from one end of the diff.
Fulltime auto I would say call the AA.
